Fan Performance
  • Thread starter JaredJames
Hi,
I have a fan heater which is rated at 2kW but when we check what it is actually using (voltage x current) it is only using 0.7kW.
I am curious as to why this is?
This is the fan:
http://www.amazon.com/dp/B000306BL4/?tag=pfamazon01-20
Are these fans 100% efficient?
Thanks
Jared James
Answers and Replies
dlgoff
1,985
At what setting are you seeing 0.7kW? The specs says it will draw 2kW when set on high and the thermostat set above the ambient temperature.
russ_watters
Mentor
20,569
7,212
If the voltage it is being run at is lower than the nominal voltage, that could explain it. Does it have a nameplate/sticker that says what voltage and amperage are nominal?
...they may have also rounded off their energy data. .7 rounds to 1. That's a pretty good possibility because you aren't allowed to make 2 kW heaters that run on regular residential wall power (in the US, anyway). A 2 kW heater would draw 16.7 A and residential circuits are 15 A.
Related Threads on Fan Performance
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
