ktoz
- 171
- 12
I see that it's possible to use mathematical notation in posts, but can't seem to find any faq that shows the required syntax. Could someone point me to a formatting reference?
Thanks
Thanks
Moonbear said:When you say you get that broken link icon, is that when you're previewing or posting?
The preferred way to format equations on this site is by using LaTeX, a typesetting language specifically designed for math and science equations. You can use the equation editor tool provided on the site or manually type in LaTeX code using dollar signs ($).
To insert a numbered equation, use the equation editor tool and click on the "Numbered" button. This will automatically add a number to your equation and update it as you make changes. Alternatively, you can manually insert a numbered equation by typing "\begin{equation} \end{equation}" in your LaTeX code.
Yes, you can include images or diagrams in your equations by using the "\includegraphics" command in LaTeX. You will need to upload the image file to the site first and then use the file name in the command. Make sure to properly size and position the image in relation to your equation.
To add subscripts or superscripts, use the underscore (_) for subscripts and the caret (^) for superscripts in your LaTeX code. For example, "x_1" will create a subscript of 1 for the variable x, and "x^2" will create a superscript of 2 for the variable x.
Yes, you can use special symbols and mathematical notations in your equations by using their corresponding LaTeX code. For example, "\alpha" will create the symbol α and "\int" will create the integral sign. You can refer to a LaTeX guide or cheat sheet for a list of all available symbols and notations.
