• Support PF! Buy your school textbooks, materials and every day products Here!
Faraday's Law Problem
  • Thread starter cse63146
1. Homework Statement
A 100-turn, 2.0-cm-diameter coil is at rest in a horizontal plane. A uniform magnetic field away from vertical increases from 0.50 T to 1.50 T in 0.60 s. What is the induced emf (in mV) in the coil?
2. Homework Equations
[tex]\Phi_m = ABcos\vartheta[/tex]
[tex]E = \frac{d \Phi}{dt}[/tex]
3. The Attempt at a Solution
[tex]E = \frac{d \Phi}{dt} = \frac{d (ABcos\vartheta)}{dt} = - \pi r^2 \frac{dB}{dt}sin\vartheta[/tex]
[tex]\frac{dB}{dt} = \frac{1}{.6} = 1.67 T[/tex]
I can "ignore" the negative sign because I just need the absolute value, and the derivative of cos = -sin
*I forgot the number ot turns in the previous equation, but I added them in the next one*
[tex]N \pi r^2 \frac{dB}{dt}sin\vartheta = (100) \pi 0.1^2 (1.67) sin60 = 45mV[/tex]
Did I make any mistakes?
Answers and Replies
G01
Your work looks correct except for the following point. (It doesn't affect your answer.)
The minus sign you ignore should cancel out anyway since:
[tex]E=-\frac{d\Phi}{dt}[/tex]
You forgot the minus sign that comes from Lenz's Law.
452
in my textbook, Farady's Law is denoted in an absolute value.
apperantly I made a calculation error. I get 4.5 V = 4.5*10^-3 mV.
EDIT: I tried 45 and 4.5*10^-3, and it says I got it wrong. Any ideas?
G01
I also get 4.5 V when I crunch the numbers. But 4.5V is 4500mV, not .0045mV.
452
I tried 4500 mV, but it still says it's wrong.
G01
OK I think I see the problem. Your radius is.01m not .1m. Does this fix the problem?
412
Firstly, i don't understand why you've taken the angle as [itex]\frac{\pi}{3}[/itex]. Since the field is vertical and the coil is in the horizontal plane, the angle is [itex]0[/itex] i.e. the area vector and the field lines are parallel. Secondly, the angle does not change with time. Hence, the term [itex]\cos(\theta)[/itex] is constant and ur mistake was taking it's derivative w.r.t time and changing it to [itex]\sin(\theta)[/itex]. My answer is coming out to be: 52.4645 mV [http://tinyurl.com/yv9w2k]
452
I'm an idiot. Should have realised that.
but why did you use 0.02 instead of 0.01 since it requires the radius and not the diameter.
412
do note that i have taken the no. of turns as '25' and not '100' i.e. i used [tex]A = \frac{\pi d^2}{4}[/tex] rather than [itex]A = \pi r^2[/itex]
452
shouldnt it be 25*pi*((0.02)^2)*(1.67)*cos60 = 26.23mV?
G01
Hmm. Must have misread the problem. I was under the assumption that the OP just forgot to post the angle. in the problem. I figured that his value of 60 was correct. Sorry for the confusion.
452
My idioticy has no bounds. The 30 degrees is from a different problem I'm working on and got those 2 mixed up.
G01
shouldnt it be 25*pi*((0.02)^2)*(1.67)*cos60?
does the question say so? If it does.. then yes. Because in the problem you presented, no mention of angle is given. The question presents that the plane of the coil and the field lines of the magnetic field are perpendicular. So, i took the angle to be 0.
452
Yes, but I already did 5/6 tries on the answer, and I have 1 more before I get a 0 on this question.
Here's the full question:
A 100-turn, 2.0-cm-diameter coil is at rest in a horizontal plane. A uniform magnetic field 60 degrees away from vertical increases from 0.50 T to 1.50 T in 0.60 s.
So would this be correct 25*pi*((0.02)^2)*(1.67)*cos60 = 26.23mV?
412
well.. if that is the full question then this should be the right answer. Is this what your textbook/assignment/whatever says?
452
this is what it says:
http://img386.imageshack.us/img386/2509/37516342im5.jpg [Broken]
i was actually asking what the textbook/assignment had to say about the 'answer'.. i didn't realize it then that this was a test you were giving. Anyways, all things considered, i think you should go with 23.24 or whatever the answer was that u got in ur previous post wherein you used cos(60).
Related Threads for: Faraday's Law Problem
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
