Faraday's law
  • Thread starter FourierX
Actually this is not exactly a homework. I am trying to understand the following situation only.
Consider a ring shaped coil of N turns and area A. Connect it to an external circuit with a twisted pair of leads ( this info is trivial). The resistance of the circuit along with the coil itself is R. Now the coil in a magnetic field.
Suppose the flux through the coil is somehow altered from its initial steady state value (A) to final value (B).
The author claims that the total charge Q that flows through the circuit as a result is independent of the rate of change of the flux. I am having hard time understanding this. Can anyone help me understand it.
[tex]\oint[/tex] E.dl = -d[tex]\Phi[/tex]/dt
faraday's law is the most relevant law here, according to the book. But I am just not getting what the author is saying.
Answers and Replies
LowlyPion
3,090
I think this lecture covers a lot of what you want to know.
http://ocw.mit.edu/ans7870/8/8.02/videolectures/wl-802-lec16-220k.ram [Broken]
(Requires Real Player, if that's not a problem for you.)
About 11 minutes in if you are in a rush.
thanks,
i followed the video. It was helpful.
However, i am still not sure about independence of charge with the rate of change of flux. On applying faraday's law
EMF = -Nd[tex]\Phi[/tex]/dt
In the condition mention in the question above, B is the final M_flux A and the initial M_flux. We are trying to derive Q such that it is independent of d[tex]\Phi[/tex]/dt.
I am confused with initial and final magentic flux. On just using d[tex]\Phi[/tex]/dt, here is what i got
I = Nd[tex]\Phi[/tex] cos(theta)/dt*(R)
and I = dQ/dt
But still Q is dependent on d[tex]\Phi[/tex]/dt.
Any clue ?
Defennder
2,591
What is cos theta here? And try equating the expression for I with V/R where V is as given by Faraday's law.
cosine theta is a mistake here. It has to be omitted.
Yeah, i did use Ohm's law there.
But my confusion at this point is, since the final and initial fluxes are given, in Faraday's formula, should emf be
emf = -N d(B-A)/dt or just -N d(flux)/dt ?
The final expression is supposed to show that Q is independent of rate of change of flux
Defennder
2,591
It should be [tex]emf = -\frac{B-A}{\delta t}[/tex].
did you forget N ?
Defennder
2,591
No I didn't. N was already included in both B and A. Remember that B, A are themselves the flux through the coil. Anyway it should make no difference in the solution.
Related Threads on Faraday's law
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
