How to Calculate Tension in a Hinged Gate with an Off-Center Load
  • Thread starter kontroll2007
  • Tags
    Gate
In summary, the problem involves a gate that is 4.00 m wide and 2.00 m high, weighing 528 N and hinged at points A and B. To relieve strain on the top hinge, a wire CD is connected at an angle of 30 degrees. The tension in wire CD is increased until the horizontal force at hinge A is zero. Using the equation for moments, it can be determined that the tension in wire CD is equal to the weight of the gate.
kontroll2007
A gate 4.00 m wide and 2.00 m high weighs 528 N. Its center of gravity is at its center, and it is hinged at A and B. To relieve the strain on the top hinge, a wire CD is connected to the gate at an angle of 30 degrees. The tension in CD is increased until the horizontal force at hinge A is zero. What is the tension in wire CD?
ΣF=0
Στ=0
τ=r*F
Fx=Tension(cos(30))
Fy + Tension(sin(30))=528
Tension(sin30)(4m)=528(2m)
Tension= 528N
This is very wrong, I am so lost and confused please help.
where relative to the center are the hinges and the wire located?
Hi kontroll2007! :smile:
Hint: if the horizontal force at A is zero, then that means the total force at A is vertical.
So if you take moments about any point on the vertical line through A, the contribution from A will be zero.
Does that help? :smile:
(erm … we can't help you any more until you tell us where C and D are … they're obviously not the other two corners of the gate! :redface:)
Sorry, but they would not let me put a link to the picture in the post. Ok D is above A on a post while C is on the side opposite the hinges.
|D
A |{---------- C
B |{----------
ok … so which point on the line DAB should you take moments about to find the tension when the force at A is vertical? :smile:
1. What is "Farmyard Gate - Equilibrium"?
"Farmyard Gate - Equilibrium" is a scientific concept that relates to the balance of energy and matter within a farming ecosystem. It refers to maintaining a sustainable and healthy equilibrium between the inputs and outputs of a farm system.
2. How does "Farmyard Gate - Equilibrium" relate to farming practices?
The concept of "Farmyard Gate - Equilibrium" is essential for farmers to understand as it helps them manage their farm in an environmentally friendly and sustainable manner. By maintaining equilibrium, farmers can ensure that their farm ecosystem remains healthy and productive for years to come.
3. What factors can disrupt the "Farmyard Gate - Equilibrium"?
There are several factors that can disrupt the equilibrium of a farm ecosystem. Some of these include overuse of pesticides and fertilizers, monoculture farming, and overgrazing. These practices can upset the balance of energy and matter in the ecosystem and lead to long-term negative effects.
4. How can farmers maintain "Farmyard Gate - Equilibrium"?
To maintain "Farmyard Gate - Equilibrium," farmers can adopt sustainable farming practices such as crop rotation, intercropping, and the use of natural fertilizers. These practices help to keep the ecosystem in balance by promoting biodiversity and reducing the dependency on chemical inputs.
5. Why is "Farmyard Gate - Equilibrium" important in modern farming?
In today's world, where industrial agriculture and unsustainable farming practices are leading to soil degradation, water pollution, and loss of biodiversity, understanding and maintaining "Farmyard Gate - Equilibrium" is crucial. It allows farmers to produce food in an environmentally friendly and sustainable manner, ensuring the long-term health of both the farm ecosystem and the wider environment.
