Fast ignition fusion approach
  • Thread starter Stanley514
Stanley514
411
Was this technique ever demonstrated experimentally, or it could be regarded as practically failed theory?
https://lasers.llnl.gov/science/ignition/fast-ignition
Answers and Replies
phyzguy
2,106
I am not sure, but I think the answer to your question is "neither". I think it is still considered a promising approach which has not yet been experimentally verified because the necessary laser hardware isn't there yet. Anybody else know more?
Stanley514
411
Is there any difficulty to construct a laser set they describe? It should be pretty easy to do?
the_wolfman
346
48
Fast ignition is an ongoing area of active research in the ICF community.
In theory both laser beams and ion beams can be used to heat the hot spot and ignite the pellet. Fast ignition requires a lot of energy being deposited in a very small volume, at a very precise time. Building such a laser or accelerator is not easy. The physics that governs how these high energy dense beams interact is also not trivial.
phyzguy
2,106
Take a look at the scale of the lasers at the National Ignition Facility. Now you have to build a new laser with a tighter focus and a very short pulse width and integrate it with the other 192 lasers which are already in place. I don't think I would describe this as "pretty easy to do."
EulersFormula
28
Fast ignition is pretty much dead. We can't make the electrons do what we want them to do. There is little funding left for it.
Morbius
Dearly Missed
1,125
EulersForumula,
I wouldn't say fast ignition "is pretty much dead", AT ALL!. As the_wolfman states, it is an ongoing area of research of the ICF research community. The research in fast ignition isn't at the experimental stage yet; but more in the theoretical and design phases as the details of the technique are worked out.
For example, there's a LOT of computer simulation of fast ignition ongoing at Lawrence Livermore, including some of the largest single simulations ever done:
https://www.llnl.gov/news/newsreleases/2013/Mar/NR-13-03-05.html
As far as the coordination mentioned by others, the delivery of the ignition pulse laser beam would be similar to coordination of diagnostics already routinely performed on NIF. While NIF has 192 lasers, not all of them may be used to drive the fusion capsule. Some of the beams may be used to drive the diagnostics, like X-ray backlighting.
Let's say thhe NIF scientists would like to get of measurement of the capsule geometry at a precise point in time during the capsule implosion to see how well the experiment matches their numerical simulations. One way to do that is to take a fast X-ray of the capsule at the time of interest.
Rather than use all 192 beams to drive the capsule, NIF uses some of the beams to irradiate a target to produce X-rays at precisely the time of interest. The X-rays "backlight" the capsule and the X-ray image is recorded on detectors to see if the position of the various shells in the capsule are where the numerical simulation predicted they would be. That means that certain beams on NIF are fired in a way different from the main group that is driving the experiment. Those beams fire so that one gets a very short pulse of laser energy which is directed at the X-ray backlighter target at the appropriate time to give the short pulse of X-rays that will record the position of the capsule shells. LLNL lasers like NIF and its predecessor Nova, have had the ability to assign different missions to different beams for decades now.
Well, if you think about it, the firing and coordination of the X-ray backlighter lasers is similar to what one needs to do when one if preparing an laser ignition pulse.
Greg
EulersFormula
28
Greg,
What you are describing is an x-ray backlighting diagnostic. This is different than trying to ignite the compressed fuel with a beam of hot electrons.
It was concluded in a National Academy of Sciences report last year that fast ignition was not the most promising path to fusion due to complications with controlling the fast electron beams. Many of the scientists who specialized in fast ignition are now changing research directions.
Morbius
Dearly Missed
1,125
Greg,
EulersFormula,
Evidently you have a reading comprehension problem because I stated explicitly in the above post that what I was describing was a backlighting diagnostic. Evidently, you didn't understand the last paragraph where I ANALOGIZED the coordination of the backlighting technique to the coordination needed for fast ignition.
There is actually renewed interest in fast ignition since the "central hot spot" technique championed in the National Academy of Sciences report FAILED to achieve fusion ignition in recent trials at the National Ignition Facility. The "central hot spot" technique requires a high degree of symmetry which is proving to be rather difficult to achieve.
As detailed in:
the fast ignition technique relaxes some of the constraints of high degree of symmetry imposed by the "central hot spot" technique.
There's lots of not well understood phenomena and much difficult physics to take into account, that it is really premature for anyone, even the National Academy to be eliminating or tossing aside any ICF approaches.
When "central hot spot" or some other scheme achieves success in achieving fusion ignition; then we can eliminate other contenders. But it would really be irresponsible to eliminate contenders as of yet.
The National Academy of Sciences has NOT done the irresponsible and called for the elimination of fast fusion; contrary to the ERRONEOUS contentions you have made earlier in the thread. Must be more of that poor reading comprehension thing.
Greg
EulersFormula
28
Why are my claims erroneous? The report specifically quotes " Conclusion 4-5: At this time, fast ignition appears to be a less promising approach for IFE than other ignition concepts." Complicated target design and problems with laser-target energy coupling were cited.
You can argue all you want about how we have the technology to create the beams that we want, but it doesn't change the fact that we are unable to achieve good energy coupling between the beam and target. You are delusional if you think fast ignition is a "hot topic" in the ICF community.
Morbius
Dearly Missed
1,125
EulersFormula,
Yes - during the past year, the approaches that the National Academy of Sciences recommended pursuing did NOT achieve ignition on NIF.
Not achieving good energy coupling, and not achieving good symmetry can also be said for the schemes that were recommended by the National Academy of Science report.
In fact, the best results that have been obtained on NIF have been using techniques pioneered by LLNL's WCI Directorate, and not the National Ignition Campaign.
https://www.llnl.gov/news/aroundthelab/2014/Feb/NR-14-02-06.html#.U4PFMnatySo
Evidently, YOU are the one that doesn't understand what work is being done when you characterize the "fast ignition" concept as being totally dead and the researchers moving on to other pursuits. As I showed previously in this thread, there is still a lot of ongoing work in pursuit of the fast ignition concept, including some of the most detailed supercomputer simulations done to date on LLNL's Sequoia supercomputer:
The fact that these simulations are being researched doesn't seem to be compatible with your characterizationn of fast ignition being a "dead" concept.
Greg
jim hardy
Dearly Missed
9,869
4,892
Fascinating !
from first link:
Boot-strapping results when alpha particles, helium nuclei produced in the deuterium-tritium (DT) fusion process, deposit their energy in the DT fuel, rather than escaping.
What discourages the alphas from going their own separate ways ?
EulersFormula
28
You are giving me a link of a fast ignition simulation dating more than a year ago. Can you tell me what useful results have been generated with since then?
I'm also not saying that there is nobody in the US who is studying fast ignition, but I am seeing a trend of researchers moving away from it. If you really do not notice this, then I am guessing that you are not actively involved in the ICF community.
If we cannot understand how normal cryo implosions are performing, then how can we possibly understand what is going on in a fast ignition scheme which has much more complicated targets?
I also don't understand your point about the hight foot campaign. That has nothing to do with fast ignition. They increased the adiabat to stabilize their implosions.
Morbius
Dearly Missed
1,125
EulerFormula,
I didn't say that the high foot work had anything to do with fast ignition. I was merely commenting that the most promising results of late have been coming from a different group, and not the ICF community. When I begin a new paragraph, then I'm beginning a new topic that not necessarily connected to the statements of the previous paragraph.
Most of the problems aren't so much with understanding the implosion; but has more to do with the drive and laser / plasma interactions, and how small perturbations in the geometry can seed instabilities that destroy symmetry.
No - I'm NOT actively involved in the "ICF community". I'm in the same field / lab directorate as the people who did the "high foot" work.
Greg
Morbius
Dearly Missed
1,125
Fascinating !
from first link:
jim,
The alphas are charged; doubly so. Each alpha has a charge of +2; so it feels the Coulomb ( electrostatic ) force from all the ions and all the electrons. That's why alpha radiation is so relatively short ranged; because the interaction is so strong. Prior to NIF, the lasers weren't as powerful and could only implode really small capsules. Because the capsules of previous lasers were so small, they couldn't trap the alphas let alone the neutrons. ( Of the 17.6 MeV of energy that comes from a D-T fusion reaction, 14.1 MeV goes to the neutron and 3.5 MeV goes to the alpha. Small capsules have very little chance of trapping the neutron; the mean-free path of a 14.1 MeV neutron in most materials is measured in 10s of centimeters ) One needs to recover the energy of the alpha in order to sustain the fusion process; just like the heat released in a fire is needed to sustain the fire. Take away the heat, and the fire goes out; which is why dousing with water is a good way to put out a fire.
Greg
mheslep
728
Fascinating !
from first link:
Inertia, for the time required, as in the name of this approach to fusion.
Astronuc
Staff Emeritus
5,251
Fascinating !
from first link:
The goal of controlled fusion is to obtain sufficient energy from the alphas to 1) heat a magnetically confined plasma, or 2) release maximum amount of thermal energy.
The disadvantage to d+t fusion is that so much energy (14.1 MeV of ~17.6 MeV) is carried away by the fast neutron. That has implications on the first wall and structures, as well as the thermal conversion system, e.g., thermal blanket, in which most of the neutron energy is deposited as heat, and then as activation of whatever structure or coolant there is.
In magnetic confinement, the alpha particles would curve around the magnetic lines as well as travel along the lines, and in the process, collide with other nuclei and electrons, thus heating the plasma. They would also recombine with electrons.
In the inertial confinement capsule, the alphas would travel in all directions, out of the capsule at the surface, and into the capsule. However, the capsule first compresses then expands. As the capsule expands, the alpha heating diminishes as does the fusion of d+t (or d+d, t+t)
Stanley514
411
Initially they proposed to use a picosecond laser as the ignitor in fast fusion. What if instead we use femtosecond or even attosecond laser for this purpose? Could it change conditions of fast fusion drammatically or not too much?
the_wolfman
346
48
We can't build a femto or attosecond laser with sufficient intensity to "spark" the fusion reaction. In order to spark fast fusion you need to deliver sufficient energy to your target. As you go to shorter pulses, the necessary intensity of your laser increases.
And let's not ignore all the physics of the laser-plama interactions. These tend to get more detrimental as you go to extreme laser intensities.
Stanley514
411
What do you mean as "intensity"? Lasers are characterized by power and energy. As we go to shorter pulses their power automatically increases, but energy requirements (for the fusion) diminish. The very point of fast ignition is to use picosecond laser which has higher power, but much smaller energy demands. I wonder what will happen if they will proceed to even much shorter pulses.
the_wolfman
346
48
Intensity is power dived by the cross sectional area of the laser pulse.
No, the energy requirement of fusion does not diminish. Why do you think that it would?
To achieve inertial fusion we have to first compress a target, and then heat the target. Success requires you to heat a "hot spot" to a specific temperature. The amount of energy to heat a hot spot of fixed size to a specific energy is fixed! This energy represents a minimum amount of energy you have to deliver to you compressed target to initiate fusion.
Stanley514
411
"If successful, the fast ignition approach could dramatically lower the total amount of energy needed to be delivered to the target; whereas NIF uses UV beams of 2 MJ, HiPER's driver is 200 kJ and heater 70 kJ, yet the predicted fusion gains are nevertheless even higher than on NIF."
http://en.wikipedia.org/wiki/Inertial_confinement_fusion#Fast_ignition
13,375
The concept is not dead, but they are far away from any realistic power plant. Both the efficiency (fusion output per energy required for the lasers) and the repetition rate (multiple shots per second instead of a few per day) would have to increase by several orders of magnitude to reach the relevant region.
"the necessary laser hardware isn't there yet" sounds much more promising than it is.
"We cannot fly to other stars with half the speed of light because the antimatter drive hardware isn't there yet".
the_wolfman
346
48
The dynamics of compresson are vary rapid. They occur on a few nanoseconds or shorter. If you want to heat a pellet mid-compression your beam needs to have a very short pulse. This is why fast fusion needs to use a short pulse laser (or ion beam).
The use of the second laser pulse to spark fusion reduces the demands on compression. Ultimatly this is why fast fusion potentially reduces the needed laser energy. This savings in unrelated to the pulse length of the "heater" laser.
Stanley514
411
But was this principle ever successfully demonstrated in an experiment? I mean successful fast ignition of at least one target with a sole lasers shot? If yes, what was energy release in comparison to energy spent? And if not, does it mean that there were a failed experiments?
13,375
I don't know about the details of their fusion tests. They can get some fusion. A while ago they announced the amount of energy released by fusion exceeded some specific part of the input energy - which was a small amount (something like 1%) of the laser energy, which itself is a tiny amount of the total grid power the facility needs for a shot.
the_wolfman
346
48
It sounds like you're talking about experimental results out of NIF. These experiments use a technique called shock ignition which is a different approach than fast ignition.
There have been a few fast ignition experiments. The results were promising enough to convince Japan to build a fast ignition facility: FIREX. I don't know what the current status of FIREX is (I believe its under construction).
Suggested for: Fast ignition fusion approach
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
