Fate vs. free will thread?
  • Thread starter hypnagogue
  • #36
Zantra
781
Predeterminism and free will shall always be at odds. One will never overtake the other one, and here's why.
For each situation presentend as free will, or as being able to introduce a change, predeterminism says "I knew about that change and figured it into the equation, so I still knew the outcome"
For every predetermined path that is chosen, free choices can be introduced that would change the path.
It's a viscious never-ending cycle of permutations that cannot be resolved. It's like an infinite number of perfectly played tic tac toe games that results in an infinite stalemate. Mentat's right, this puzzle has no real solution.
  • #37
russ_watters
Mentor
21,850
8,807
Which is why I dropped out of the discussions. I made my point, I think you understood it and I think you understood mine. Not much left to say. Some philisophical discussions just come down to that - a difference in worldview.
  • #38
THANOS
218
It is possible to resolve this. But cannot be solved soon. The answer lies in the question if our universe is by chance or created.
If by chance then free will is most likely to be the effect. If our universe is created then fate is most likely to be in effect.
There is also the middle of both conclusions. That the beginning and the end is predetermined and free will exist in the middle for it doesn't matter how messy the middle is the end result will be the same. Like a squirt gun, the beginning being the water in the squirt gun and the end is the water that evaporates. So it doesn't matter who you shoot or where you shoot the ending is ultimately the same.
  • #39
Mentat
3,918
Listen to my man Zantra here, he knows these things .
Seriously, this is what I've been saying for quite some time (way back when I was 'bout your age, Zantra, in the old PF2 :wink:), and I'm glad to see that I'm not the only one who gets it.
  • #40
Mentat
3,918
Actually, THANOS, the question of whether our Universe came about by chance or was predestined is merely another incarnation of the exact same question: is reality predestined or does "free will" exist? It is as impossible to determine whether the Universe came about by chance or was predestined as it is to determine that of any other occurance.
As to the "middle ground" that you propose, I disagree. If you read Zantra's previous posts, you see that every factor about what we may choose to do (in the free will paradigm of course) must be discernable in order to predict the outcome; thus, if the end is predestined, then everything in between must also occur a certain way.
  • #41
THANOS
218
lets say that our beginning is only 2 things. Matter and Anti-matter now lets say its doesn't matter what this matter does. Because ultimately in the end the matter will end. It doesn't matter how long it takes to end for our universe has patience. Perhaps this way when the universe starts again it might not be a limbo. But then again this is one out of many possible infinite answers.
like the dirt that makes foundation it will ultimately go back into dirt.
of course this thread is about free will and fate so lets not go too deep in space.
  • #42
MpJ!3Fr33
Science only explains the behavior of the universe in which we live in, and attempts of deciphering human actions via mathematics have all failed.
There might be a simple way to see ourselves as predestined. For example if I drop a ball on the floor, there was a 100% chance of me dropping it because I did.
  • #43
The following is an argument for partial determinism:
There is a marked difference between absolute freedom and a sense of freedom in the perceptual processing of reality in human beings. The existence of absolute freedom as opposed to the mere concept of freedom is as abstract as perfection in its ideal form. Perfection is the condition whose symmetry cannot be broken and which exists at the end of an infinite number of operations (e.g. PI at its infinith decimal place represents a perfect circle). Absolute freedom can only exist in the absence of choice because choice... can only exist within a system of constraint. That is because human beings make choices based on the interest of self or others for the most part. The act of making a decision is analogous to solving a problem and problems are solved by algorithms. Human beings run their list of choices through some mental construct that functions as an algorithmic basis for determination. The consequent freedom in the outcome of choice is based solely on maximizing utility or best interest. However, there exists an alternate standard measure by which to determine a choice based on two other properties - right and wrong which themselves, are the products of a more universal algorithm that is totally independent of oneself yet, exists within oneself. This algorithm implies a far higher level of complexity and hence intelligence.
The "BEST" choice is supposed to be the one that allows escape from a given system of constraints and hence, freedom. But, the choice itself is based on some kind of interest be it self or other. To give rise to absolute freedom an infinite number of operations need be taken. Whereas, on a finite or limited mental algorithm the outcome is but a sense of freedom. Since perfection is the condition of absolute freedom that would mean that absolute freedom from constraint can only exist at the end of an infinitely complex algorithmic proceedure. Thus, freedom is abstract and independent of the physical self. However, when one's choices are run through the universal algorithm a consequent solution it measured upon the inner conscience of oneself and worldly interests may be placed aside or not depending on whether one chooses right or wrong.
  • #44
Tigron-X
71
We are affected by fate, and we have free will.
Fate is simply the consequences we experience for the choices we make. We have the free will to decide how we will deal with the consequences that we are confronted with, and that will be our fate becuase we cannot control the consequences of our choices and the rules that apply to choices. The only way we are able to choose our fate is if we know the rules that will be applied in a given situation and the consequences of the choices we derive through our own imagination or predesposed beliefs that is better defined as instinct.
  • #45
Yank
Look back on anything you've ever done when you felt you could have done something differently in the exact same situation. That would imply that two identical situations could have different outcomes, which would imply that the universe isn't deterministic. The only alternative to determinism is randomness. You still wouldn't have free will then, because in a random universe nothing could control anything (if true randomness can even exist, which I doubt).
  • #46
Tigron-X
71
No, the universe is still deterministic. Recognize that you're an acting force in a situation and you'll see what I mean. If you do something differently than before, then you changed the situation from the way it was when you made your initial decision. Thus, you have a different outcome. Your decisions aren't determined by the universe, and that's what free will is all about. You have the ability to determine your experiences by chosing from a predetermined set of consequences that you may or may not see in a given situation at a given time. And even then, you still have the ability to decide how you will deal with the outcome of your decision(s) as life goes on with or without you.
It's similar to this. In the game of poker, you can't choose the cards you're dealt, but you can choose the way you'll play those cards, and that will determine whether you'll win or lose. Again, your CHOICES are the determining factor, NOT YOU even though the choice was made by you.
There's a fine line between God and Man, and we can walk it any way we choose.
  • #47
tluong13
Sorry to tell you that we have no free will at all about our fate!
By some way and some how our life was programed (likes a very complex computer program) when we was born.
And there is two parts of our mind: Concious part and unconcious part, and that un- concious part (sixth scence) is the program, it controls every of your thoughts, your actions, your reactions, your words...., it knows everything that will be happened in our life time, and it controls every steps of our life to make sure these thing will happen as it was programed, it is our destiny.
That explains a lot of things that we observed in the course of our life, why some body do this, why another boby do that so they escaped the death or walk in the death by themseves etc...
It looks like we have the free will but actually that free will is the product of our un-concious part, the one we call our fate, our destiny.
So we just enjoy our life, it does not matter what our life turn out, just enjoy it as long as we still alive and thanks God for all the things He made for us, a human being.
Suggested for: Fate vs. free will thread?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
