- #36
Russell E. Rierson
- 384
Hawking writes:
So information is encoded on the 2-dimensional boundary of spacetime.
Information about the quantum states in a region of spacetime may be somehow coded on the boundary of the region, which has two dimensions less. This is like the way that a hologram carries a three dimensional image on a two dimensional surface.
http://www.encyclopedia4u.com/t/topological-space.html [Broken]
Any metric space turns into a topological space if define the open sets to be generated by the set of all open balls. This includes useful infinite-dimensional spaces like Banach spaces and Hilbert spaces studied in functional analysis.
http://www.encyclopedia4u.com/m/metric-space.html [Broken]
Metric space
A metric space is a space where a distance between points is defined. It is a topological space.
Formally, a metric space is a set of points M with an associated distance function (also called a metric) d : M × M -> R (where R is the set of real numbers). For all x, y, z in M, this function is required to satisfy the following conditions:
d(x, y) ≥ 0
d(x, x) = 0 (reflexivity)
if d(x, y) = 0 then x = y (identity of indiscernibles)
d(x, y) = d(y, x) (symmetry)
d(x, z) ≤ d(x, y) + d(y, z) (triangle inequality).
These axioms express intuitive notions about the concept of "distance": distances between different spots are positive and the distance between x and y is the same as the distance between y and x. The triangle inequality means that if you go from x to z directly, that is no longer than going first from x to y, and then from y to z. In Euclidean geometry, this is easy to see. Metric spaces allow this concept to be extended to a more abstract setting.
A metric space in which every Cauchy sequence has a limit is said to be complete.
Metric spaces are paracompact Hausdorff spaces and hence normal (indeed they are perfectly normal). An important consequence is that every metric space admits partitions of unity and that every continuous real-valued function defined on a closed subset of a metric space can be extended to a continuous map on the whole space (Tietze extension theorem). It is also true that every real-valued Lipschitz-continuous map defined on a subset of a metric space can be extended to a Lipschitz-continuous map on the whole space.
Two metric spaces (M1, d1) and (M2, d2) are called isometrically isomorphic iff there exists a bijective function f : M1 → M2 with the property d2(f(x), f(y)) = d1(x, y) for all x, y in M1. In this case, the two spaces are essentially identical. An isometry is a function f with the stated property, which is then necessarily injective but may fail to be surjective.
Every metric space is isometrically isomorphic to a closed subset of some normed vector space. Every complete metric space is isometrically isomorphic to a closed subset of some Banach space.
Distance between points and sets
If (M,d) is a metric space, S is a subset of M and x is a point of M, we define the distance from x to S as
d(x,S) = inf {d(x,s) : s ∈ S}
Then d(x, S) = 0 if and only if x belongs to the closure of S. Furthermore, we have the following generalization of the triangle inequality:
d(x,S) ≤ d(x,y) + d(y,S)
which in particular shows that the map x |-> d(x,S) is continuous.
