Homework Help: Fermionic static structure factor
  1. Oct 1, 2015 #1
    Calculate the static structure factor for noninteracting fermions
    [itex]S(\vec{q})=\frac{1}{N}\langle \phi_0|\hat{n}_{\vec{q}}\hat{n}_{-\vec{q}} | \phi_0\rangle[/itex]
    where [itex]\hat{n}_\vec{q}=\sum_{\vec{k},\sigma} a^\dagger_{\vec{k}\sigma}a_{\vec{k}+\vec{q}\sigma}[/itex] is the particle density operator in the momentum representation and [itex]|\phi_0\rangle[/itex] is the ground state. Take the continuum limit [itex]\sum_{\vec{k},\sigma} \to 2V\int \frac{d^3 k}{(2\pi)^3}[/itex] and calculate [itex]S(\vec{q})[/itex] explicitly.
    Hint: Consider the [itex]\vec{q}=0[/itex] and [itex]\vec{q}\neq 0[/itex] separately.
    2. Relevant equations
    The spin-independent one-particle operator: [itex]\langle\vec{q}|O|\vec{k}\rangle =\frac{1}{V}\int d\vec{r} e^{-i(\vec{q}-\vec{k})\cdot\vec{r}} O(\vec{r})[/itex]
    3. The attempt at a solution
    The case [itex]\vec{q}=0[/itex]:
    In that case, the operator [itex]\hat{n}_\vec{q}\hat{n}_{-\vec{q}}=\sum_{\vec{k},\sigma} a^\dagger_{\vec{k}\sigma}a_{\vec{k}+\vec{q}\sigma}a^\dagger_{\vec{k}\sigma}a_{\vec{k}-{\vec{q}}\sigma}
    =\sum_{\vec{k},\sigma} a^\dagger_{\vec{k}\sigma}a_{\vec{k}\sigma}a^\dagger_{\vec{k}\sigma}a_{\vec{k}\sigma}[/itex]
    means that the integral reads
    [itex]S(0)=\frac{2V}{N}\int \frac{d^3 k}{(2\pi)^3} n^2_{\vec{k}\sigma} = 1[/itex].
    The physical process, in the [itex]\vec{q}\neq 0[/itex] case, is as follows: there is a particle at location [itex]\vec{k}[/itex] in momentum space within the Fermi sphere of radius [itex]k_F[/itex] that gets annihilated, and is created back with momentum [itex]\vec{k}-\vec{q}[/itex], which lies outside of the Fermi sphere, due to Pauli's exclusion principle. Said particle is annihilated and created back at the hole it first left behind.
    Due to this constraint, if there was some spherical-coordinate integral to evaluate in the [itex]\vec{q}\neq 0[/itex] case, the radial integration limits would probably be [itex]k_F-|\vec{q}|,k_F[/itex]. But this is as far as I have taken the integral:
    [itex]S(\vec{q})=2\int \frac{d^3 k}{(2\pi)^3} e^{-i\vec{k}\cdot\vec{q}} a^\dagger_{\vec{k}\sigma}a_{\vec{k}+\vec{q}\sigma}a^\dagger_{\vec{k}\sigma}a_{\vec{k}-{\vec{q}}\sigma}[/itex]
    I'd like to think I am getting stuck at a rather advanced stage...
  3. Oct 6, 2015 #2
    Thanks for the post! This is an automated courtesy bump. Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Have something to add?
Draft saved Draft deleted
