Homework Help: Feynman-Hellmann Theorem
  1. Feb 15, 2008 #1
    cepheid
    Staff Emeritus
    Suppose the Hamiltonian H for a particular quantum system is a function of some parameter λ. Let En(λ) and ψn(λ) be the eigenvalues and eigenfunctions of H(λ). The Feynman-Hellmann Theorem states that
    [tex] \frac{\partial E_n}{\partial \lambda} = \left \langle \psi_n \left | \frac{\partial H}{\partial \lambda} \right | \psi_n \right \rangle [/tex] ​
    assuming that either En is non-degnerate or --- if degenerate, that the ψn's are the "good" linear combinations of the degenerate eigenfunctions.
    a) Prove the Feynman-Hellman Theorem Hint: Use Equation 6.9
    b) Apply it to the 1D Harmonic Oscillator (i) using λ=ω (this yields a formula for <V>), (ii) using λ = ħ (this yields <T>), and (iii) using λ = m (this yields a relation between <T> and <V>.
    2. Relevant equations
    Equation 6.9 is for the first order correction to the energy, given H' is the perturbation:
    [tex] E_n^1 = \langle \psi_n^0 | H^\prime | \psi_n^0 \rangle [/tex] ​
    3. The attempt at a solution
    I said to represent a perturbation as a small change in λ:
    [tex] H(\lambda + \delta \lambda) = H(\lambda) + \frac{\partial H}{\partial \lambda} \delta \lambda [/tex]​
    to first order.
    Similarly
    [tex] E_n(\lambda + \delta \lambda) = E_n(\lambda) + \frac{\partial E_n}{\partial \lambda} \delta \lambda [/tex]​
    So, since the first order term in the expansion of the Hamiltonian above is just H', and the first order term in the expansion of the energy above is just E1n, equation 6.9 becomes:
    [tex] \frac{\partial E_n}{\partial \lambda} \delta \lambda = \left \langle \psi_n \left | \frac{\partial H}{\partial \lambda} \delta \lambda \right | \psi_n \right \rangle [/tex] ​
    Then I just divided both sides by δλ to get the result. What I'm wondering is, I just made this up. Is it a valid proof? Wikipedia has another method that makes use of the definition E = <H> and nothing else:
    http://en.wikipedia.org/wiki/Hellmann-Feynman_theorem
    However, this method doesn't use the given equation 6.9. That's all I'm asking about for now. I have a question about part b as well, but I'll wait until we get part a out of the way.
  3. Feb 16, 2008 #2
    kdv
    Your way of doing it sounds completely right to me.
  4. Mar 3, 2008 #3
    cepheid
    Staff Emeritus
    Thanks for weighing in on that kdv. I have a question about part (b) which is as follows:
    Apply it (the Feynman-Hellman theorem) to the one-dimensional harmonic oscillator, (i) using λ =ω (this yields a formula for <V>).
    So we have:
    [tex] E_n = \left(n+\frac{1}{2}\right)\hbar \omega [/tex]
    [tex] \frac{\partial E_n}{\partial \omega} = \left \langle \psi_n \left | \frac{\partial H}{\partial \omega } \right | \psi_n \right \rangle [/tex]
    [tex] \left(n+\frac{1}{2}\right)\hbar = \left \langle \psi_n \left | \frac{\partial }{\partial \omega }\left (-\frac{\hbar^2}{2m}\frac{d^2}{dx^2} \right) + \frac{\partial}{\partial \omega}\left(\frac{1}{2}m\omega^2x^2\right) \right | \psi_n \right \rangle [/tex]
    bear with me (continued in next post)
  5. Mar 3, 2008 #4
    cepheid
    Staff Emeritus
    When I was doing this problem, my classmates said that the first term in the central portion of the right hand side (dT/dw) should be zero, because "that part of the Hamiltonian doesn't depend on omega". To me, however, differentiating T with respect to omega is meaningless. T is a differential operator. The only reasonable way for me to interpret this:
    [tex] \frac{\partial H}{\partial \omega} [/tex]
    is that it is itself an operator of the form AB, where A = d/dw and B = H. Applying this operator to [itex] | \psi_n \rangle [/itex] consists of first having H act on psi, and then having d/dw act on the RESULT of that. Is that true? Does...
    [tex] \frac{\partial H}{\partial \omega}|\psi_n \rangle = \frac{\partial}{\partial \omega}(H |\psi_n \rangle) [/tex]
    If so, that hugely complicates the calculation. You can't just differentiate V wrt omega and you don't get an expression for <V> as Griffiths claimed you would. I guess I just don't understand the math well enough to deal with this problem. If you really are allowed to differentiate H first, before it acts on anything, what the hell does that MEAN?
  6. Mar 3, 2008 #5
    kdv
    I think that one way to think about it is to take the derivative with respect to the parameter before even quantizing. That is, you take the derivative on the classical hamiltonian. Then you quantize. So it gives that the kinetic operator does not contribute.
  7. Mar 3, 2008 #6
    cepheid
    Staff Emeritus
    Hey...now THAT's an interesting possibility I hadn't considered. Does anyone know what the rules are regarding when the canonical substitution is supposed to be made?
    Thanks again for weighing in kdv.
  8. Mar 4, 2008 #7
    cepheid
    Staff Emeritus
    Nobody?
  9. Mar 4, 2008 #8
    I think you're overthinking it. There is no reason why you can't take the derivative of an operator, or the derivative of an expression involving an operator.
