How does graded-index material reduce pulse spreading in optical fibres?
In summary, the textbook is talking about pulse spreading/dispersion in optical fibres. Chromatic dispersion occurs because the refractive index of the fibre is different for different frequencies (colours) of light ... the pulse will have 'spread'. Alternative paths (called 'modes') along the fibre result in multi-mode dispersion which can be reduced by using a graded-index material for the fibre core. The result is that the light travels more quickly towards the edge of the fibre, compensating for the extra distance it has to travel. The refraction occurs gradually as the light moves towards the edge of the fibre, so the light is always bent back towards the centre of the fibre and total internal reflection does not happen
Barclay
208
[/B]
The textbook is talking about pulse spreading/dispersion in optical fibres.
Book says: "The spreading of the pulse is due to two dispersion effects:
(i) Chromatic dispersion occurs because the refractive index of the fibre is different for different frequencies (colours) of light ... the pulse will have 'spread'.
Don't really understand how refractive index can be different for different frequencies. Isn't it meant to be that different frequencies are refracted by different amounts by the same refractive index material?
(ii) "If the width of the fibre is larger than the wavelength of the light there will be alternative paths (called 'modes') along the fibre.
Each path is a slightly different length so the pulse arrives spread over a longer time. This multi-mode dispersion can be reduced by using a graded-index material for the fibre core. Here, the refractive index of the core material reduces gradually from the centre to the edge".
The result of this is that the light travels more quickly towards the edge of the fibre, compensating for the extra distance it has to travel. The refraction occurs gradually as the light moves towards the edge of the fibre, so the light is always bent back towards the centre of the fibre and total internal reflection does not happen.
Don't really understand how total internal reflection does not happen. The whole topic I am reading is about the advantages of total internal reflection in fibre optics.
(Hope a moderator does not complain about the use of colours. Its meant to make the reading easier ... that's why I did it here. Otherwise just just looks too long to read.
[/B]
Please help. High school physics level
Its not that internal reflection doesn't happen, rather it doesn't need to happen because the rays are curved by the graded refractive index. Remember light is bent when it moves from one refractive index to another.
So the light is channeled through the optical fibre by refraction & internal reflection?
1. What is fibre optics pulse spreading?
Fibre optics pulse spreading refers to the phenomenon of a light pulse spreading out and becoming wider as it travels through an optical fibre. This can be caused by various factors such as dispersion, scattering, and nonlinear effects.
2. Why does pulse spreading occur in fibre optics?
Pulse spreading occurs in fibre optics due to the physical properties of the material and the environment it is travelling through. These properties cause the light pulse to experience changes in velocity and direction, leading to its spreading and distortion.
3. How does pulse spreading affect data transmission in fibre optics?
Pulse spreading can significantly impact data transmission in fibre optics by causing distortion and delays in the transmitted signal. This can result in errors and loss of information, leading to decreased performance and reliability of the system.
4. What are some techniques used to mitigate pulse spreading in fibre optics?
Some common techniques used to mitigate pulse spreading in fibre optics include dispersion compensation, chromatic dispersion management, and nonlinear optics. These methods involve manipulating the properties of the fibre and the transmitted signal to minimize the effects of pulse spreading.
5. How does the length of the fibre optic cable affect pulse spreading?
The length of the fibre optic cable can have a significant impact on pulse spreading. As the light pulse travels through a longer distance, it has more time to interact with the material and the environment, leading to more significant spreading. This can be mitigated by using dispersion compensation techniques or by using shorter fibre optic cables.
