Homework Help: Field axioms
  1. Jul 8, 2009 #1
    hall,
    i need to prove by using the field axioms that:
    (-a)(-b)=ab, i think i know how to this but I'm very insecure with using those
    axioms cause i want to make sure I'm not using my intuition.
    i tried something like: (-a)(-b)=(-1)(a)(-1)b=(-1)(-1)(a)(b)=ab and i guess it's wrong (in the formal way).
    could someone show me how this mechanism works in this case?
    thanks,
    Omri
  3. Jul 8, 2009 #2
    Well the way you presented it, you actually used what you were trying to prove in the last equality.
    Can you prove that -(ab) = (-a)(b)? The hint is that you'll need the distributive property. If you can prove this, then (-a)(-b) = ab is the exact same proof.
  4. Jul 8, 2009 #3
    so if i undrstood you correctly, i can write
    -a(b+(-b))=0
    -ab+(-a)(-b)=0
    ab-ab+(-a)(-b)=0+ab
    (-a)(-b)=ab
    is that too much stepd for an answer?
    thanks
    Omri
  5. Jul 9, 2009 #4
    I think you are implicitly using the fact that (-a)b = -ab, but otherwise that looks fine.
  6. Jul 9, 2009 #5
    You will have to cite which axiom you are using at each step.
    You probably have them listed with some numbering, so use that.
  7. Jul 9, 2009 #6
    HallsofIvy
    You need to understand that, in the field axioms, "-a" does NOT mean (-1)(a). It means "the additive inverse of a". In order to prove that (-a)(-b)= ab, you need to show that "if x+ a= 0 and y+ b= 0, then xy= ab". You might start by looking at (x+a)(x+b)= 0(0)= 0.
    (Yes, you can then show that if x+a= 0, x= -1(a) where "-1" is defined as the additive inverse of the multiplicative identity but I was talking about using the axioms.)
