• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Figuring out pullies, Please help me
  • Thread starter rk2658
1. Homework Statement
A mass M1 of 3kG is suspended from one corner by a fixed rope, 1, and from another corner by a rope, 2 which passes over a pulley and is connected to a mass M2 of 2kG, and
suppose that at time t = 0 both masses are at rest and the angles made by the
ropes are each π/4 = 45 degrees. Neglect friction in the pulley and the mass of the rope.
This situation is not stable. The blocks will start to move. Please determine the
acceleration of mass 1.
A picture of this is on this page
http://phys.columbia.edu/~millis/1601/assignments/PHYC1601Fall2011Assignment4.pdf
2. Homework Equations
F= ma
3. The Attempt at a Solution
Okay so I was able to break up to the forces for both masses.
For the mass of 3 kgs:
Fy= (T1+T2)sin(45) - 30= 3ay
Fx= (T2-T1)cos(45)= 3ax
For the mass of 2 kgs:
Fy=T1-20= 2a
Also since the accelerations of both masses must be the same I know that:
ay^2 + ax^2 =a ^2
Also I'm supposed to use the fact that since one rope is attached to a wall it doesn't move so that the distance travelled only really happens with pulley.
I don't know what to do from here, any help would be greatly appreciated. Thank you.
NascentOxygen
Mentor
9,182
1,031
ax=ay=a.cos(45)
so replace these in the above equations.
Fy=T1-20= 2a
using this result, substitute for T1 in the above pair of equations
And you are left with 2 equations in 2 unknowns. Solve for a.
why is ax=ay= a cos(45) ?
NascentOxygen
Mentor
9,182
1,031
Your question has caused me to look at this more closely. I'm not completely confident that I have it right, even now.
Fixed by a rope on the left, the C of G of M1 is constrained to swing in an arc about that fixed rope's anchor point. With the geometry of the diagram, M1's tangential motion currently is along a 45 deg line.
ay^2 + ax^2 =a ^2
it is too general an expression, and turns out to be insufficient [for me] to solve for a. It doesn't include everything we know about ax and ay.
Subtract the two equations to eliminate T2. Then substitute for T1, leaving you with an equation in a, ax, and ay.
It looks like it's almost solvable using ay2 + ax2=a2, but is difficult. But if you set horiz and vert components of a to be equal, it's easy.
Related Threads for: Figuring out pullies, Please help me
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
