Homework Help: Filtering with Matlab
  1. Nov 9, 2009 #1
    TFM
    I have got a table of data, and want to use Matlab to sort this data and filter out some variables. The data was orginally in a FITS format.
    2. Relevant equations
    N/A
    3. The attempt at a solution
    Sorry if this is the wrong thread.
    I have tried two different versions of code:
    hd = (data{12} < rsd);
    data_filtered = filter(hd,data,:);
    and
    idx = (rs < rsd);
    data_filtered = data(:,idx);
    I need it to filter out all data with a Redshift less then a specified number
    Any ideas or thoughts would be really appreciated
    Thanks,
    TFM
  3. Nov 11, 2009 #2
    TFM
    Okay, I have found that the data seems to be in a 1x55 table which is the reason I am having trouble filtering it - I get a error message about matrix dimensions.
    Any ideas the best way to sort this kind of table?
    Many thanks,
    TFM
  4. Nov 13, 2009 #3
    TFM
    Okay I was told Matlab had put my Data in a wierd way so I have now entered the data into a Structure. Does the Filter command still work for Structures, as using the code:
    idx = (datastruct.Redshift < rsd);
    data_filtered = datastruct(idx)
    Gives me a Matrix Error:
    ??? Index exceeds matrix dimensions.
    Error in ==> DensityFunct3 at 12
    Any ideas would be greatly appreciated
    Many Thanks
    TFM
  5. Dec 22, 2009 #4
    I think the problem is in the index of datastruct, as it is showing. May be the length of data_filtered is not the same as datastruct. It is very common problem occurs in MATLAB. For Example : if H=[1:5]; and then Y=[1:7]; and if you do H=Y(15); then it occurs. Hope it is helpful
