Final Speed Question
  • Thread starter Westin
An object with mass 161kg moved in outer space. When it was at a location [PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png7,-17,-9[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.pngm [Broken] its speed was 18m[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmmi10/alpha/144/char3D.pngs. [Broken] A single constant force [PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png143,308,-396[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.pngN [Broken] acted on the object while it moved to a location [PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char68.png14,-25,-15[PLAIN]https://s3.lite.msu.edu/adm/jsMath/fonts/cmsy10/alpha/144/char69.pngm. [Broken] What is the speed of the object at this final location?[/B]
W=Fd
F=ma
KE=1/2mv^2
v^2=u^2+2as
1) Used F=ma
<143,308,-396> = 161a
a=<.888,1.913,-2.46>m/s
2) Plugged numbers into v^2=u^2+2as to get final velocity, I did it 3 times because of vectors so I got Vf= <18.342,17.192,18.802>
3) I took <18.342,17.192,18.802> and did sqrt(18.342^2+17.192^2+18.802^2) and got 31.358m/s[/B]
Answers and Replies
TSny
3,156
Hello, Westin.
For the x-component, you would have ##v_x^2 = u_{x}^2 + 2a_x\Delta x##. But, you don't know ##u_x##.
I think work and energy concepts are going to be a better approach here.
The section we are covering is currently energy so I think you're right.
Second attempt:
1) W=Fd
W= (<143,308,-396> )(<7,-8,-6>)
W= <1001,-2464,2376>
2) Kfinal = Kintial + W
Kinital = (1/2)mv^2 = (1/2)(161)(18)^2 = 26082J
Kfinal = 26082J + <1001,-2464,2376>J
Kfinal = <27083, 23618, 28458> J
3) Kfinal / mass = Final velocity
<27083, 23618, 28458> / 161 = <168.217, 146.696, 176.758>m/s
4) sqrt(168.217^2+146.696^2+176.758^2) = 284.71m/s
Incorrect once again :/
TSny
3,156
Second attempt:
1) W=Fd
Work is a scalar quantity, not a vector quantity.
does everything else look good besides that?
TSny
3,156
You have the correct overall approach.
But note that KE is also a scalar quantity!
TSny
3,156
Check this.
Related Threads on Final Speed Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
12K
  • Last Post
28K
