Final velocity need help
final velocity...need help!!
An object is to be thrown through a window 3.25 m high a distance 8 m away. It is launched at an angle 75 degree above the horizontal.
The initial launch speed at the specified angle which will allow the projectile to pass through the window is 13.3 m/s.
What is the final speed of the object (that is, the speed at which it flies through the window)?
Y= height
Yo= initial height
Voy= initial speed
Vf= final velocity
g= gravity
t= time
1)Y= Yo+Voy*t-(1/2)gt^2
2)Vf= Vo+at
3. The Attempt at a Solution
By using the y= yo+Voy*t-(1/2)gt^2 formula,
= 3.25+ (13.3sin75)t-(1/2)(-9.81)t^2
I found the time t=2.85 s
But then the answer i got by using the formula Vf= Vo+at
= 13.3+ (-9.81)(2.85)
= -14.7 m/s
IS wrong!!What is my mistake??
Answers and Replies
tiny-tim
25,836
251
Welcome to PF!
Hi theoronhalde ! Welcome to PF! :smile:
(try using the X2 and X2 tags just above the Reply box :wink:)
But then the answer i got by using the formula Vf = Vo+at
= -14.7 m/s
Vfy = Voy + at :wink:
hi!! thx a lot!!
Not sure i understand your answer? Do i have to use the formula you wrote instead of the one i was using to fnd the final velocty? I'm a bit confuse...
tiny-tim
25,836
251
Yes … you have to deal with the y-components separately. :smile:
(the x-component of velocity, of course is constant :wink:)
ok s it's going to be:
Vfy= Voy+at
= 13.3sin75+ (-9.81)(2.85)
= -15.1 m/s
But how come the horizontal velocity be constant? And am I suppose to use
V=Sqrt((Vox^2)+(Vfy^2)) to find that final speed?
tiny-tim
25,836
251
The horizontal acceleration is zero, so the horizontal velocity must be constant.
And yes, use Pythagoras. :smile:
oh ok....i undestand what you are saying but i still end up with a wrong answer...here is what i did:
Vfx= Vox + at (a=0)
=13.3cos75
Vfy= Voy+at
= 13.3sin75 + (9.81)(2.85)
= -15.1
Vf= SQRT( Vfy^2 + Vfx^2)
= 15.5 m/s
The applet says that the answer is wrong :S ??
tiny-tim
25,836
251
I haven't checked how you got t using Vy, but when I do it using Vx, I don't get 2.85.
oh...i'm so lost once again. I tought we should get the time By using:
If not can you explain me how to find the time and how to get the components Vfy and Vfx.
Related Threads on Final velocity need help
  • Last Post
  • Last Post
  • Last Post
F
  • Last Post
9K
