Homework Help: Find all possible values of h
  1. Dec 29, 2015 #1
    Find all possible values of h.
    fh(a+bx+cx2+dx3) =
    [ a+b+c+hd b+c ]
    [ -b-c-hd hb ]
    2. Relevant equations
    3. The attempt at a solution
    1) Row reduce the matrix
    [ a+b+c+hd b+c ]
    [ -b-c-hd hb ]
    to (R1+R2)
    [ a hb+ b+c ]
    [ 0 hb ]
    to (R1-R2)
    [ a b+c ]
    [ 0 hb ]
    a+b+c = 0
    hb = 0
    From this row reduction I assume b=0, a=1 and c=-1
    h could still be any number though.
    So I got back to the original matrix.
    a+b+c+hd+b+c=0
    -b-c-hd+hb=0
    If I plug in the values I assumed (above) then I get d=-1 and h=-1
    Is there a better / quicker way to do this? I seem to come across a lot of similar problems.
  3. Dec 29, 2015 #2
    mfb
    2017 Award
    Staff: Mentor
    I don't understand the notation. Is fh a function? If yes, does the h in the name matter and what do you know about the function? Or is that a simple multiplication?
    The right side is a 2x2 matrix? If yes, is the equation true for a given x, or just for an arbitrary x?
  4. Dec 29, 2015 #3
    It's a linear transformation
  5. Dec 29, 2015 #4
    mfb
    2017 Award
    Staff: Mentor
    fh? Of a real number to 2x2 matrices of real numbers? An arbitrary one?
    My crystal ball isn't working properly today, so I cannot know that if you don't write it.
  6. Dec 30, 2015 #5
    haruspex
    Just guessing here, is the matrix in the fh equation supposed to be surrounded by vectors involving x, maybe [1 x], [1 x]T?
  7. Dec 30, 2015 #6
    It's a P3 to M2x2 linear transformation. The first part of the question, which I'm having difficulty understanding, asks to find all possible values of h. I'm confused because h can have many many values, depending on what the values of x,y,z are and depending on what I set the polynomial of the matrix equations equal to.
    i.e.
    [ a+b+c+hd b+c ]
    [ -b-c-hd hb ]
    a+b+c+hd + b+c = 0
    -b-c-hd+hb = 0
    In this case I can row reduce the matrix to simplify both equations
    a + hb + b+c = 0
    0 + hb = 0
    My confusion here is that I can see hb = 0, but h could be 0 or b could be 0 and h could be any number. So I don't really know how I'm supposed to answer this question. 'Find all possible values of h' ... Well h = 0, h ≠ 0 (essentially saying h= 1,2,3,4,5,6,7,....etc)
  8. Dec 30, 2015 #7
    With my row reducing of the matrix (above) and setting both equations from the matrix = 0 I can show that h could = 0 or it could equal a positive number of a negative number. So is it enough for me to say all possible values of h are 0,1,-1 ?
  9. Dec 30, 2015 #8
    haruspex
    I must be missing something. It seems to me that fh constitutes a linear transformation regardless of the value of h.
    You know the definition of a linear transformation, right? How would you check that fh is such?
  10. Dec 30, 2015 #9
    Yes. The second part of the question asks for the kernel and image. I know how to do that, but I'm confused with how i find all possible values of h.
  11. Dec 30, 2015 #10
    haruspex
    Well, if you apply the definition of a linear transformation, can you either deduce something about h or show that it is a linear transformation regardless of h?
    For the kernel and image, they will depend on h, no?
  12. Dec 30, 2015 #11
    That's what confuses me. If I take the original matrix and split it into two equations and make them = 0 then my value of h depends on my value of a,b,c,d and vice versa.
    a+b+c+hd + b+c = 0
    -b-c-hd + hb = 0
  13. Dec 30, 2015 #12
    haruspex
    I don't understand why two equations. If P is in the kernel, what matrix would fh(P) be?
  14. Dec 30, 2015 #13
    Isn't writing the matrix of the linear transformation:
    [ a+b+c+hd _ b+c | 0 ]
    [ -b-c-hd _ hb | 0 ]
    the same as writing them as two equations?
    a+b+c+hd + b+c = 0
    -b-c-hd + hb = 0
  15. Dec 30, 2015 #14
    haruspex
    you've lost me. The linear transformation of interest is fh. That effectively maps a four vector to a four vector, so its matrix would be written as a 4x4.
    Try to answer my question. If P is in the kernel of fh what does the 2x2 matrix fh(P) look like?
  16. Dec 30, 2015 #15
    I don't understand your question. sorry.
  17. Dec 30, 2015 #16
    haruspex
    For the purposes of the question, the set of polynomials of degree 3 is just a vector space here. Likewise the set of 2x2 matrices over R. fh is a linear transformation from the first to the second.
    When we say that an element X is in the kernel of a linear transformation T, what equation expresses that?
  18. Dec 30, 2015 #17
    fh: P3 → M2x2
    Ax = 0
  19. Dec 30, 2015 #18
    haruspex
    Right, so write that last equation out for the case where x is the polynomial a+bx+cx2+dx3.
  20. Dec 30, 2015 #19
    I don't know how to format this, but it's the original 2x2 matrix * (1,x,x2,x3) = 0, only 1,x,x2,x3 would be a column.
    [ a+b+c+hd b+c ] * ((1,x,x2,x3) = 0
    [ -b-c-hd hb ]
  21. Dec 30, 2015 #20
    But we'd need a 4x4 matrix for A though for this to work...
  22. Dec 30, 2015 #21
    HallsofIvy
    So this is
    [tex]f_h(a+ bx+ cx^2+ dx^3)= \begin{bmatrix} a+ b+ c+ hd & b+ c \\ -b- c- hd & hb \end{bmatrix}[/tex]
    from the space of polynomials of degree 3 (or less) to the space of 2 by 2 matrices. And the problem is to find all possible values of h such that what?
    As says says, since this is from a 4 dimensional vector space to a four dimensional vector space, it would be written
    as a 4 by 4 matrix. Taking the "obvious" bases for the two spaces, [itex]\{1, x, x^2, x^3\}[/itex] and [itex]\{\begin{bmatrix}1 & 0 \\ 0 & 0 \end{bmatrix}, \begin{bmatrix}0 & 1 \\ 0 & 0 \end{bmatrix}, \begin{bmatrix}0 & 0 \\ 1 & 0 \end{bmatrix}, \begin{bmatrix}0 & 0 \\ 0 & 1 \end{bmatrix}\}[/itex], this maps [itex]1= 1+ 0x+ 0x^2+ 0x^3[/itex] (a= 1, b= c= d= 0) to [itex]\begin{bmatrix}1 & 0 \\ 0 & 0 \end{bmatrix}[/itex], it maps [itex]x= 0+ 1x+ 0x^2+ 0x^3[/itex] (b= 1, a= c= d= 0) to [itex]\begin{bmatrix}1 & 1 \\ -1 & h\end{bmatrix}= \begin{bmatrix}1 & 0 \\ 0 & 0 \end{bmatrix}+ \begin{bmatrix}0 & 1 \\ 0 & 0 \end{bmatrix}- \begin{bmatrix}0 & 0 \\ 1 & 0 \end{bmatrix}+ h\begin{bmatrix}0 & 0 \\ 0 & 1\end{bmatrix}[/itex], it maps [itex]0+ 0x+ 1x^2+ 0x^3[/itex] (c= 1, a= b= d= 0) to [itex]\begin{bmatrix} 1 & 1 \\ -1 & 0\end{bmatrix}= \begin{bmatrix}1 & 0 \\ 0 & 0 \end{bmatrix}+ \begin{bmatrix}0 & 1 \\ 0 & 0 \end{bmatrix}- \begin{bmatrix}0 & 0 \\ 1 & 0 \end{bmatrix}[/itex], and maps [itex]0+ 0x+ 0x^2+ 0x^3[/itex] (d= 1, a= b= c= 0) to [itex]\begin{bmatrix} h & 0 \\ -h & 0\end{bmatrix}= h\begin{bmatrix} 1 & 0 \\ 0 & 0 \end{bmatrix}- h\begin{bmatrix}0 & 0 \\ 1 & 0 \end{bmatrix}[/itex]
    So the matrix representing this linear transformation, in these bases, is
    [tex]\begin{bmatrix} 1 & 1 & 1 & h \\ 0 & 1 & 1 & 0 \\ 0 & -1 & -1 & -h \\ 0 & h & 0 & 0 \end{bmatrix}[/tex].
    Now, again, exactly what is it you want to do with, or know about, this matrix?
  23. Dec 30, 2015 #22
    mfb
    2017 Award
    Staff: Mentor
    Thanks Halls, that clarifies a lot.
    A good question would be "which values of h make the kernel non-trivial".
  24. Dec 30, 2015 #23
    I need to find all possible values of h and then find the kernel and image of each matrix with respect to the value/s of h.
  25. Dec 30, 2015 #24
    mfb
    2017 Award
    Staff: Mentor
    I don't see any restriction on h.
    Most values of h will lead to the same result for kernel and image.
  26. Dec 30, 2015 #25
    Ray Vickson
    I don't think the question makes any sense as written. Assuming you mean
    [tex] f_h(a + bx + cx^2 + dx^3) = \pmatrix{a+b+c+hd&b+c\\-b-c-hd & hb} [/tex]
    or (better)
    [tex] F_h ([a,b,c,d]) = \pmatrix{a+b+c+hd&b+c\\-b-c-hd & hb} [/tex]
    then what prevents me from taking any value of ##h## that I want? Why can't I take ##h = 272.63##, or ##h = -107## or ##h = \sqrt{\pi/2}##? For any value of ##h## that I decide to use I will get a ##2 \times 2## matrix having that ##h## in it as a parameter.
    If you had meant (but not stated) that you want all values of ##h## that give the mapping ##f_h## some desired property, that would be a different question, and it might well make sense. In that case, you need to spell out what that desired property might be. Or, perhaps, you want Ker(f_h) or Im(f_h), and want to figure out their dimensionalities and the like, as functions of h. Whatever it is you want to do, you need to tell us!
Have something to add?
Draft saved Draft deleted
Loading...
