Find capacitance physics help
In summary, the two capacitors, C1 and C2, are initially charged to different potentials of 20 V and 4 V respectively. After connecting the plates with opposite charges, the total potential difference becomes 2 V. By using the equations Q=CV and U=(1/2)QV, we can determine that the capacitance of C1 is 11µF.
Qwerty459
Capacitor C1 is charged so that potential difference between its plates is 20 V. Another capacitor C2=33µF has potential difference of 4 V between its plates. After plates of the capacitors that carry the charge of opposite sign were connected the potential difference became 2 V. Find capacitance C1.
Q=CV
U=(1/2)QV=(1/2)CV2
I know that the charge on C2 is initially 122µC and that the potential energy on C2 is initially 2.64*10-4 J.
The answer to the problem is supposed to be 11µF, but I don't know how I am supposed to figure this out having been given only the initial potential for C1.
Qwerty459 said:
and that the potential on C2 is initially 2.64*10-4 J.
You mean potential energy.
_____________________________
Take charge on C1 as (C1)20 ... write charges on the 2 capacitors after they are connected, take charge on any1 capacitor as Q1 ... so on other will be net charge left - Q1.
keep in mind that charges will cancel out as opposite charge plates are connected.
Now potential of both capacitors is 2V
write eqn Q=CV for 2 capacitors and eliminate Q1
you'll get C1
you'll get C1
Yes, Potential Energy.
Treat the two connected plate as something parallel (as they should hold the same potential)
And by conservation of charges, compute the results. Note that we have "cancellation" of charges as we are connecting to the opposite side.
To solve this problem, we can use the conservation of charge and energy principles for capacitors.
First, we know that the total charge in the system must remain constant before and after the capacitors are connected. This means that the total charge on C1 and C2 before connection must equal the total charge on C1 and C2 after connection. Mathematically, this can be represented as:
Q1 + Q2 = Q1' + Q2'
Where Q1, Q2 are the initial charges on C1 and C2 respectively, and Q1', Q2' are the final charges on C1 and C2 respectively.
Next, we can use the formula Q=CV to relate the charge to the capacitance and potential difference. This means that we can rewrite the above equation as:
C1V1 + C2V2 = C1'V1' + C2'V2'
Where C1, C2 are the initial capacitances of C1 and C2 respectively, and C1', C2' are the final capacitances of C1 and C2 respectively.
Now, we can use the given information to solve for C1'. We know that the initial potential difference of C1 is 20 V, and the final potential difference is 2 V. This means that V1 = 20 V and V1' = 2 V. We also know that C2 = 33µF, V2 = 4 V, and V2' = 2 V. Plugging these values into the above equation, we get:
C1(20) + 33(4) = C1'(2) + 33(2)
Simplifying, we get:
20C1 + 132 = 2C1' + 66
Subtracting 2C1 from both sides, we get:
18C1 + 132 = 66
Subtracting 132 from both sides, we get:
18C1 = -66
Dividing both sides by 18, we get:
C1 = -3.67µF
This is not the answer we were looking for, so we need to check our work. We can see that the negative sign indicates that our initial assumption of the charge on C1 being positive was incorrect. This means that the charge on C1 must have been negative before connection. This also means that the potential difference across C1
1. What is capacitance in physics?
Capacitance is a measure of an object's ability to store electrical charge. It is defined as the ratio of the electric charge stored on an object to the potential difference across the object.
2. How do you calculate capacitance?
The formula for calculating capacitance is C = Q/V, where C is the capacitance, Q is the charge stored on the object, and V is the potential difference across the object.
3. What are the units of capacitance?
The SI unit of capacitance is Farad (F), named after Michael Faraday. One Farad is equal to one Coulomb of charge per Volt of potential difference. Other commonly used units include microfarads (μF), nanofarads (nF), and picofarads (pF).
4. How does capacitance affect an electric circuit?
Capacitance can affect an electric circuit in several ways. It can store electrical energy, block or allow the flow of current, and cause a time delay or phase shift in AC circuits. It also plays a crucial role in many electronic components, such as capacitors and transistors.
5. What factors affect capacitance?
The capacitance of an object is affected by several factors, including the size and shape of the object, the distance between the plates (in the case of a capacitor), and the type of material used. It also depends on the dielectric constant of the material between the plates, which determines how well it can hold an electric charge.
