Optimized Find dS for Sphere of Radius 3 Below Phi=π/6
  • Thread starter Feodalherren
  • Tags
    Sphere
In summary: The ##x,y,z## each use a factor of ##3## in their formulas.Wait, you lost me. When I look at the result of your cross product, they all have a 9 in them.Nevermind I got it. Thank you!
Feodalherren
605
Let S be the piece of ρ=3 that is below Φ=∏/6 and is oriented up. Write one dS (vector) for all of S.
It's a sphere of radius 3.
[itex]S=<x,y,\sqrt{9-x^{2}-y^{2}}>[/itex]
Therefore
[itex]dS = < \frac{-x}{\sqrt{9-x^{2}-y^{2}}}, \frac{-y}{\sqrt{9-x^{2}-y^{2}}}, 1 >[/itex]
Sorry accidentaly pressed the enter key, one moment while I edit the post with the problem.
Therefore
First of all, that doesn't look right even in the first octant. There upward normal would be outward and all three components of ##d\vec S## should be positive.
Aside from that, I don't understand the orientation question. Orientation is to pick one side of the surface as "positive". The way this problem is described, it uses one side on the upper part and the other side on the lower part. I don't get the "one" dS vector for all of S.
Yeah dude you tell me... This professor loves to throw curve balls at his students. I've never seen anything like this in a book or anything and yes the question confuses me too.
Without any justification what so ever he puts down the answer as
[itex]dS=\frac{<x,y,z>}{3} 9Sin\phi d\phi d\theta [/itex]
where x=ρSin(phi)cosθ
and the other spherical coordinate definitions...
I get where the spherical dA transformation comes from, and the 9. But since no work is shown I am completely and utterly confused. I think I'm just going to memorize what to do for the test and not even care about understanding it. I'm so over this class.
That answer is simply incorrect. If you parametrize the sphere as$$
\vec R(\phi,\theta) = \langle 3\sin\phi \cos\theta,3\sin\phi\sin\theta,3\cos \phi\rangle$$and calculate ##\vec R_\phi \times \vec R_\theta## as you normally would to get a normal vector you get$$
\vec R_\phi \times \vec R_\theta =
\langle 9\sin^2\phi\cos\theta, 9\sin^2\phi\sin\theta, 9\sin\phi\cos\phi\rangle
= \langle 3x\sin\phi, 3y\sin\phi, 3z\sin\phi\rangle=\langle x,y,z\rangle 3\sin\phi$$That gives you the expression your prof has, but it represents the outward pointing normal for the sphere, which is downward on the bottom half.
Perhaps there is confusion in the statement of the problem, wanting oriented outwards instead of oriented upwards.
Likes 1 person
I was looking through my notes and I think that's what he's after. He called it "special case two".
How are you reducing your 9 to a 3? I did it the way you did it and when I factor out the 9 it just remains as a 9.
Likes 1 person
1. What is the significance of optimizing the find dS for a sphere?
Optimizing the find dS (differential surface area) for a sphere allows for a more accurate measurement of the surface area at a specific point on the sphere, taking into account the curvature of the sphere.
2. How is dS calculated for a sphere?
The formula for calculating dS for a sphere is dS = r^2 * sin(θ) * dθ * dφ, where r is the radius of the sphere, θ is the polar angle, and φ is the azimuthal angle.
3. What is the value of dS when Phi=π/6?
When Phi=π/6, the value of dS can be calculated by plugging in the given values into the formula dS = r^2 * sin(θ) * dθ * dφ. It is important to note that the polar angle θ must also be specified in order to calculate the value of dS.
4. How does the value of dS change as Phi increases?
As Phi increases, the value of dS also increases. This is because as the polar angle θ increases, the surface area of the sphere at that point becomes larger, resulting in a larger value for dS.
5. Can dS be optimized for other shapes besides a sphere?
Yes, dS can be optimized for other shapes besides a sphere, such as cylinders, cones, and ellipsoids. The formula for calculating dS will vary depending on the shape and its parameters.
