Homework Help: Find f(x) from following data
  1. May 30, 2013 #1
    utkarshakash
    If f(x/y) = f(x)/f(y) f(y)≠0 and f'(1)=2 find f(x).
    2. Relevant equations
    3. The attempt at a solution
    Diff both sides wrt x
    f'(x/y)*1/y=f'(x)/f(y)
    putting x=1
    f'(1/y)*1/y=2/f(y)
  3. May 30, 2013 #2
    Your first step is wrong. Apply chain rule.
  4. May 30, 2013 #3
    utkarshakash
    I have differentiated wrt x treating y as a constant.
  5. May 30, 2013 #4
    tiny-tim
    hi utkarshakash! :smile:
    ok so far
    now you need a relation between f(1/y) and f(y) :wink:
  6. May 30, 2013 #5
    Ah yes, sorry about that. Now as tiny-tim said, a relation between f(y) and f(1/y) would be useful.
    Hint: Put x=1 in the original equation. :smile:
  7. May 30, 2013 #6
    haruspex
    You might find the path a little more obvious if you differentiate wrt y instead. Note that you can easily deduce f(1).
  8. May 31, 2013 #7
    utkarshakash
    How to find that?
  9. May 31, 2013 #8
    tiny-tim
    apply the formula in the question to f(1/y)
  10. May 31, 2013 #9
    AGNuke
    If I had to guess, I'd say ##f(x)=x^2##.
  11. May 31, 2013 #10
    utkarshakash
    Yes the answer is correct.
  12. May 31, 2013 #11
    tiny-tim
    ok, now derive it! :rolleyes:
  13. May 31, 2013 #12
    utkarshakash
    f(1)=f(y)f(1/y)
  14. May 31, 2013 #13
    tiny-tim
    ok, now combine that with your original equation …
    … to get a differential equation in f(1/y) :wink:
    (also, isn't it fairly obvious what f(1) is?)
  15. May 31, 2013 #14
    Please can you help me understand a very important concept and i.e why have we differentiated wrt x treating y as a constant .
    Isnt x and y both variable ? Why is applying chain rule to differentiate wrong as earlier suggested by Pranav-Arora ?
    Thanks
  16. May 31, 2013 #15
    tiny-tim
    yes, x and y are independent variables, and so we can ∂/∂x keeping y constant, or ∂/∂y keeping x constant :wink:
    i think you've misread that …
    everybody's been applying the chain rule
  17. May 31, 2013 #16
    I have been trying this question from quite some time and I always ended up with the same differential equation you are talking about but I don't see a way to solve it.
    What I end up with is this:
    [tex]\frac{∂f(1/y)}{∂x}\cdot \frac{1}{y}=2f(1/y)[/tex]
    I don't see how can i solve this but if I replace y with 1/x, I do get the right answer but is it valid to replace y with 1/x?
    Thanks!
  18. May 31, 2013 #17
    Thanks tiny-tim for clarification...Yes I indeed misread things
  19. May 31, 2013 #18
    utkarshakash
    f'(1/y)/f(1/y)=2y (Assuming x=1)
    But I haven't learned how to solve DE's.
  20. May 31, 2013 #19
    utkarshakash
    Yes of course it is valid. Since the function is valid for all y belonging to ℝ.
    But can you tell me the method to solve this equation? I haven't been taught DE yet.
  21. May 31, 2013 #20
    I still don't get this. :confused:
    Assuming that replacing y with 1/x is valid,
    [tex]\frac{∂f(x)}{∂x}\cdot x=2f(x)[/tex]
    Rearranging,
    [tex]\frac{∂f(x)}{f(x)}=2\frac{∂x}{x}[/tex]
    You do know how to solve this now. (##\int dx/x=\ln x+c##)
  22. May 31, 2013 #21
    Mute
    The equation you've written here isn't correct. The derivative is with respect to the entire argument of f, not just x, because of the chain rule:
    $$\frac{\partial}{\partial x} f(x/y) = \left.\frac{df}{dz}\right|_{z = x/y} \frac{\partial(x/y)}{\partial x} = \left.\frac{df}{dz}\right|_{z = x/y} \frac{1}{y}.$$
    You can then set x = 1 to get ##\left.\frac{df}{dz}\right|_{z = 1/y} \frac{1}{y}## on the left hand side. Because the derivative is with respect to the argument of f, and not just x or y, you can legitimately change variables and it doesn't affect the ##\left.\frac{df}{dz}\right|_{z = 1/y}## term except that you're replacing 1/y with x.
    Of course, if everyone were to just follow haruspex's advice the solution would come about much more quickly:
  23. May 31, 2013 #22
    tiny-tim
    no, f'(1/y) is ∂f(1/y)/∂(1/y) :wink:
  24. May 31, 2013 #23
    tiny-tim
    the first thing is to write 1/y = z, to make things easier! :smile:
    f'(z)/f(z) = 2/z
    then
    f'(z)/f(z) dz = 2/z dz
    now integrate both sides :wink:
  25. May 31, 2013 #24
    But OP said he differentiated the equation w.r.t x. :confused:
  26. May 31, 2013 #25
    tiny-tim
    let's see …
    he used the chain rule …
    ∂/∂x f(x/y)
    = ∂/∂(x/y) f(x/y) * ∂(x/y) ∂x
    = ∂/∂(x/y) f(x/y) * (1/y) :smile:
    … what rule did you use? :wink:
Have something to add?
Draft saved Draft deleted
