Find the mass of one element of a sample
  • Chemistry
  • Thread starter jackthehat
  • Tags
    Element Mass
In summary, we have 2 moles of K in 1 mole of K2CrO4. For 1 mole of substance, we have 78.1966 g. So how many moles of the substance do we have if our sample contains just 0.67 g of K? We have 0.00856 moles. The mass of K2CrO4 in 0.00856 moles is (0.00856 x 194.1903) g.
jackthehat
41
A sample of potassium chromate, K2CrO4, is analyzed and found to contain exactly 0.67 grams of potassium. What is the mass of this sample of potassium chromate?
Formula mass = (2 x K) + (1 x Cr) + (4 x O)
1 mole of K2CrO4 has formula mass of ((2 x K) + (1 x Cr) + (4 x O)) g
=> ((2 x 39.0983) + (1 x 51.9961) + (4 x 15.9994)) g = 194.1903 g
we have 2 moles of K in 1 mole of K2CrO4 = (2x 39.0983) g = 78.1966 g
so for 1 mole of substance we have 78.1966 g
=> 1 mole x (0.67/78.1966) = 0.00856 moles
So the mass of K2CrO4 in 0.00856 moles is ( 0.00856 x194.1903) g
=> Mass of K2CrO4 of this sample is 1.66386 g
Now I was not sure of the number of significant figures required for the solution
since we were originally given the amount 0.67 g of K
I was unsure if this is to 2 or 3 significant figures so I gave the answer to both
I put down 1.66 g (to 3 sig fig) and 1.7 g (to 2 sig fig)
But both answers appear to be incorrect … can anyone help I am stuck ?
As far as I can tell, your numbers are right. A more direct way to do it might have been to use the ratio $$\frac{2\times 0.39}{2\times0.39 + 52 + 4\times 16} = \frac{0.67}{M}$$
Likes jim mcnamara
Hi etotheipi,
Thank you for taking the time to look at my problem and for your advice. it has been a help to me to see the problem tackled in an alternative way. much appreciated.
Regards,
jackthehat
Likes BillTre and etotheipi
You meant to write 39 not 0.39?
The correct answer is 1.7, not 1.66 or 1.67. This question it's from coursera!
0.67gK* (1molK/39.098gK)*(1molK2CrO4)*(194.188gK2CrO4/1molK2CrO4) = 1.7g (not 1.66g or 1.67g)
K = 2*39.098
Cr=51.996
O=4*15.999
K2CrO4=194.188 g
That's a matter of significant figures. Yes, data contains only two, so the answer should contain two as well. But significant figures are faulty by design and most people I know are not too religious about them.
Unfortunately some homework checking systems are very strict, which leaves impression as if SF really mattered. They don't. They do help explaining the intuition behind answer like 1.66385112651956734 not making any sense, but that's all.
Besides, OP stated 1.7 wasn't accepted as the correct answer.
I would never use the elements' atomic mass to six significant figures ! - two or three is the normal way to work, as several of the others have used.
While you're doing the right math, I think it's most reassuring if you put everything into a standard format where you can cross out the units. Start by asking yourself what the question is, fill in the unit you need to end up with as part of a conversion factor, and continue until you have your answer:
? g K2CrO4 = (____ g K2CrO4 / ____ mol K2CrO4) x ( ____ mol K2CrO4 / ____ mol K) x (____ mol K / ____ g K) x ( ___ g K)
Then just fill in the numbers so all the conversion factors (the things in parentheses) are equal to 1
= (194.19 g K2CrO4 / 1 mol K2CrO4) x (1 mol K2CrO4 / 2 mol K) x ( 1 mol K / 39.10 g K) x (0.67 g K)
= 1.7 g K2CrO4
Now to be sure, that's what everyone else got, so there's probably a mistranscription somewhere, but at the first line, with all the blanks unfilled, you should know you have the right answer, and the rest is just button-pushing.
On the other hand, maybe it's the sig figs. They say it's a mass of EXACTLY 0.67 g, don't they? As in 0.6700000000...? :) [no, seriously, nobody's that insane. I hope. Until I read a newspaper that is.]
1. How do you find the mass of one element of a sample?
To find the mass of one element of a sample, you will need to use a balance or scale to measure the mass of the entire sample. Then, you will need to use the atomic mass of the element to calculate the mass of one atom or molecule of that element.
2. What is the atomic mass of an element?
The atomic mass of an element is the average mass of one atom of that element, taking into account all of its naturally occurring isotopes and their relative abundance. It is typically measured in atomic mass units (amu) or grams per mole (g/mol).
3. How do you calculate the mass of one atom of an element?
To calculate the mass of one atom of an element, you will need to divide the atomic mass of the element by Avogadro's number (6.022 x 10^23). This will give you the mass of one mole of the element, which can then be converted to the mass of one atom.
4. Can the mass of one element in a sample vary?
Yes, the mass of one element in a sample can vary depending on the isotopic composition of the sample. Isotopes are atoms of the same element that have different numbers of neutrons, resulting in slightly different atomic masses.
5. Why is it important to know the mass of one element in a sample?
Knowing the mass of one element in a sample is important for various reasons. It can help determine the purity of a sample, aid in chemical reactions and stoichiometry calculations, and provide insight into the structure and properties of the element.
9K
