Find the change in pressure
  • Thread starter gruba
Two balloons are connected by a faucet.
Gas in the first balloon is at pressure [itex]p_1=100kPa[/itex], and in the second is [itex]p_2=0,5MPa[/itex].
Volumes are [itex]V_1=0,12m^3[/itex] and [itex]V_2=0,5m^3[/itex].
Temperature of a gas is constant.
Find pressure in balloons [itex]p[/itex] after faucet is opened (balloons are not connected).
[itex]pV=\frac{m}{M}RT[/itex] - state of ideal gas
State of gas before before balloons are disconnected is
[itex]p_1V_1=\frac{m}{M}RT,p_2V_2=\frac{m}{M}RT[/itex]
and after balloons are disconnected is
[itex]p(V_1+V_2)=\frac{2mRT}{M}\Rightarrow p=\frac{2p_1p_2}{p_1+p_2}=166,67kPa[/itex].
Is this correct? How volumes [itex]V_1[/itex] and [itex]V_2[/itex] are not relevant in the equation for [itex]p[/itex]?
Answers and Replies
haruspex
Insights Author
2020 Award
36,718
7,073
##p_1V_1=\frac{m}{M}RT,p_2V_2=\frac{m}{M}RT##
Are m and M the same for both?
Mass of a balloon [itex]m[/itex] and atomic mass [itex]M[/itex] are not given. Could you elaborate how to set the equations
for finding the pressure [itex]p[/itex] in second case (disconnected balloons)?
haruspex
Insights Author
2020 Award
36,718
7,073
You can assume M is the same for both, but not m. Assign two different unknowns. You have enough equations to cope with that.
I'm not sure as I'm only just learning this stuff myself though it appears I'm a couple of weeks behind you but wouldn't it be worth finding the mass flow rate? Sorry if that's wrong.
haruspex
Insights Author
2020 Award
36,718
7,073
I read the question as asking about the final state, after flow has ceased and temperatures have returned to ambient.
(Otherwise there is not enough information.)
Related Threads on Find the change in pressure
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
