Find the derivative (1 Viewer)
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
Find f'(x) if it is known that
[tex]\frac{d}{dx}[f(2x)] = x^2[/tex]
I let u(x) = 2x, then
[tex]\frac{d}{dx}[f(u)] = \frac{dy}{du} \frac{du}{dx}[/tex]
[tex]\frac{d}{dx}[f(2x)] = 2 \frac{dy}{du}[/tex]
therefore
[tex]\frac{dy}{du} = \frac{1}{2}x^2[/tex]
then
[tex]f'(x) = \frac{dy}{dx} = \frac{dy}{du} \frac{du}{dx}[/tex]
[tex] = (\frac{1}{2}x^2) (2)[/tex]
[tex] = x^2[/tex]
why doesn't this work??
137
u have f'(2x) = x^2
first find f(2x) and try to write it as a function of (2x)
and then after u do that substitute x for 2x
you therefore find f(x) finally derive it and you obtain f'(x)
does it make any sense?
yeah, i think so.
137
let me know what your answer is to see if you did it right
Well, i kinda cheated and looked at the solutions manual:tongue2:
Using the chain rule:
[tex]\frac{d}{dx}[f(2x)] = 2 f'(2x) = x^2[/tex]
[tex]f'(2x) = \frac{1}{2}x^2[/tex]
then let u(x) = 2x
[tex]f'(u) = \frac{1}{2} (\frac{u}{2})^2[/tex]
[tex]f'(u) = \frac{1}{8} u^2[/tex]
then substitute x for u:
[tex]f'(x) = \frac{1}{8} x^2[/tex]
Is there an easy to understand explanation why my original method did not work?
137
hehe good
my method was simple: f'(2x) = x^2 --> f(2x) = x^3 / 3
we multiply the denominator and numerator by 8 --> f(2x) = 8x^3 / 24
---> f(2x) = (2x)^3 / 24 ---> f(x) = x^3 / 24 --> f'(x) = x^2 / 8
137
your mistake was taking partial derivatives
u write f'(x) = dy/dx = (dy/du)/(du/dx)
since y and u are both functions of x u can not apply the partial derivative (the chain rule formula)
Thanks A_I_, I like your method :tongue:
can you expand on what you said my mistake was? I'm not sure I understand.
137
the chain rule is used when u have:
f(x,y) and x=g(t) and y=r(t)
but since your f and your u are both functions of x,
thus you can not use the chain rule and you can not say:
f'(x) = (dy/du)*(du/dx)
ok?
Yeah, i think I understand.
Can you explain that function syntax? I've seen it before, but I've always learned the simple f(x) not f(x,y)
and for composite functions (using the chain rule), f(x) = g(r(x))
137
what do you exactly want to know?
do you want an example of the chain rule?
what you wrote: f(x)= g(r(x)) is (gor)(x) and is different from the chain rule.
do you have an im?
i know what the chain rule is.
i just want to know what f(x,y) means and what "f(x,y) and x=g(t) and y=r(t)" means.
137
here you go
VietDao29
1,417
What do you mean by partial derivative here??? You only encounter partial derivative in multi-variable function, not 1 variable function like f(x)!!!!
ok?
NOOO!!!!!! What do you mean by this??? I am TOTALLY lost!!!
Why can't you use the chain rule in that case? Am I misssing something? :confused:
Please look back at your cal textbook, see the part that covers the chain rule.
[tex]\frac{df}{dx} = \frac{df}{du} \times \frac{du}{dx}[/tex]
Example:
[tex]\frac{df(2x)}{dx} = \frac{df(2x)}{d(2x)} \times \frac{d(2x)}{dx} = 2 f'(2x)[/tex].
Now, let's do your problem in a slightly different way:
[tex]\frac{df(2x)}{dx} = 2 f'(2x) = x ^ 2[/tex]
[tex]\Rightarrow f'(2x) = \frac{x ^ 2}{2}[/tex]
Now, let y = 2x, we have:
[tex]f'(y) = \frac{(2x) ^ 2}{8} = \frac{y ^ 2}{8}[/tex]
Now, what's f'(x)?
Can you go from here? Is there anything unclear? :)
Whoops, looking back at some previous posts of this thread, I saw that you've looked through the manual.
The only error you made is that you were trying to find dy / dx, which means you were finding d(f(2x)) / dx, not d(f(x)) / dx (which means the same as f'(x)).
Is there anything unclear, endeavor? :)
Example:
Now, what's f'(x)?
for the first part, thats what i was trying to tell him,
that we only use the chain rule when we have a multivariable function, which is not the case.
As for the second part, i am not sure about it, because i know you can only use the chain rule with multivariable function.
Did u consider x and 2x to be two different variables, if yes, then it works.
VietDao29
1,417
What do you mean???
Chain rule can be used for both multivariable functions, and 1 variable function.
You must have studied [tex]\frac{df}{dx} = \frac{df}{du} \times \frac{du}{dx}[/tex] BEFORE studying multi-variable functions, no?
As I told you before, you should re-read your calculus textbook, just look up the chapter for Chain rule (or you can just click on the link) for one variable function. That won't do you any harm, I promise. :wink:
I get what you've said.
Thanks for the explanation
So when in my first post I wrote:
[tex]\frac{dy}{du}[/tex]
that really means
[tex]\frac{d f(2x)}{du}[/tex]
since y = f(2x) ?
and then later on, when I wrote:
[tex]\frac{dy}{dx} = \frac{dy}{du} \frac{du}{dx}[/tex]
I was actually finding f'(2x), which was already given??
VietDao29
1,417
that really means
since y = f(2x) ?
Yes, this is correct. :)
Nah, this is not correct, you are finding:
[tex]\frac{df(2x)}{dx}[/tex], not f'(2x).
[tex]\frac{df(2x)}{dx} \neq f'(2x)[/tex].
To find f'(2x), you must find: [tex]\frac{df(2x)}{d(2x)}[/tex].
Can you get this? :)
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
