Homework Help: Find the Error
  1. Oct 29, 2016 #1
    y=1/(x^1/4). I'm given 5 x's and 5y's. I need to write Newton interpolating polynomial and find the error.
    2. Relevant equations
    Ln-1(x)=f(x1)+f(x1,x2)(x-x1)+...
    3. The attempt at a solution
    With the formula above I wrote the Newton interpolating polynomial but I can't find the error since I don't have the formula. Can anyone help?
  3. Oct 29, 2016 #2
    Ray Vickson
    First show your work.
    When you say you "don't have the formula..", what do you mean? Are you unsure how to find the Newton polynomial, or unsure how to find the error? Have you consulted your textbook and/or course notes? Have you looked on-line for topics related to "Newton interpolation"?
  4. Oct 29, 2016 #3
    Mark44
    Staff: Mentor
    What does this mean?
    Is "Ln-1(x)" supposed to be "ln-1(x)" (i.e., ex)? How is what you wrote relevant to your problem?
    Also, you wrote f(x1) and f(x1, x2). Is f a function of one variable or is it a function of two variables? It can't be both.
    The formula for what? It looks like you're supposed to approximate ##f(x) = \frac 1 {x^{1/4}}## using a term or two from the Taylor series.
  5. Oct 29, 2016 #4
    x | 1 | 2 | 5 | 16 | 39
    y | 1 | 0.8 | 0.6 | 0.5 | 0.4
    I found the Newton interpolating polynomial:
    P4(x)=1+(-0.2)*(x-1) + (0.04)*(x-1)(x-2) + (-0.003)*(x-1)(x-2)(x-5) + A(x-1)(x-2)(x-5)(x-16)
    I wrote this looking at an example we wrote in class. But we haven't written the error in any example nor I have the formula. But in this exercise I need to find the error.
    f(x1,x2) etc. these are the divided differences which are used to make up the Newton Interpolating polynomial, -0.2, 0.04 etc in this case, which I calculated too
    Should I calculate the error with this formula? R(x) = f(x)-Ln-1(x)≤ Mn/n! * (x-x1)(x-x2)*...*(x-xn)?
  6. Oct 29, 2016 #5
    lurflurf
    The error term is
    f(x,x1,x2,x3,x4,,x5)(x-x1)(x-x2)(x-x3)(x-x4)(x-x5)
    often we use a mean value argument to replace f(x,x1,x2,x3,x4,,x5) with
    $$\frac{f^{(5)}(\xi)}{5!}$$
    where the derivative is evaluated at an unknown point between the largest and smallest of
    x,x1,x2,x3,x4,x5
  7. Oct 30, 2016 #6
    Isn't that the function deviation in the range x=x1÷x5? I need to find that?
  8. Oct 30, 2016 #7
    lurflurf
    The deviation and error are the same right? This is an interesting question. If I calculated correctly M is 9945/1024~10 but that is quite pessimistic as 0.0002 models the error well. Overall that is a quite bad approximation especially around 30.
Have something to add?
Draft saved Draft deleted
