Find the forces on a table that is lifted in a tilted position
In summary, the homework statement is discussing homework equations and the attempt at a solution. My logic is that Fa = Wa - N = mg - ##\frac{N}{\cos \theta}## so Fb = 1. However, I know that this is wrong and need to find another equation to find Fa and Fb. Can anyone give me a clue? Clearly FA + FB = W. To find what fraction of W is each force you need another equation. Consider the sum of torques acting on the box.
Helly123
581
what's the Fa and Fb?
my logic is
so is Fb...
so the ratio is 1. But I know it's wrong. What will make the difference between Fa and Fb?
can anyone give a clue please?
Likes Helly123
My logic is there are 3 torques
Torque at A
Normal force*L (clockwise)
Torque at B
Normal force*L (counter clockwise)
Torque for W
mg cos thetha*L
FA + FB = W.
What should i do next?
Is the w do torque?
Is it necessary to find the w torque? Is the length for W torque is L?
Generally, a torque is only meaningful about a stated axis. To combine torques in an equation they must all be using the same axis.
What point are you taking as axis? Do all the forces have a torque about that point? (Often it helps to choose an axis that is in the line of action of one of the unknown forces, so that force does not appear in the equation.)
Look carefully at the diagram. In what direction are FA and FB?
I use the table surface as the axis. So the Normal force already perpendicular to it. And W cos theta perpendicular to it.
Is it right?
Pointing up. Perpendicular to ground. And parallel to W.I am confused to choose which point as point load for the W.
Is it necessary to find point load? Can you give me a clue?
The axis will be a single line, viewed end-on in the diagram, so appearing as a point.
Obvious choices are A, O, B or G.
So not normal to the table top, yet you mention "normal force".
Do you understand how to calculate the torque of a force about an axis?
The mass centre is shown as point G.
Wait. I meant the Normal force perpendicular to the table. So is normal. Lol
Where in the diagram is there a force normal to the tabletop?
No.. i guess i made it up myself.. why there is no Normal Force? So only Fa Fb and W?
Yes.
Of course, each has a component that's normal to the tabletop.
Please choose an axis.
Likes Helly123
More to the point, choose a reference point about which you will find expressions for the torque. What is a good choice for such a point?
This as far as my brain works. Can you give me clues?
If your origin is as indicated by the arrow in your drawing then
(a) The signs of the torques are inconsistent with one another. Follow whatever convention you wish, but torques that tend to rotate the box in the same direction must have the same algebraic sign. Torques do not necessarily have positive or negative signs because the forces that generate them are positive (up) or negative (down).
(b) Recheck the lever arms that are associated with the torques. One of them is incorrect.
Likes Helly123
how about this? Sorry for the rotation. I cannot change it
The torque equation is correct. However, your answer should not have FB or mg on the right side otherwise you will not be able to select the correct choice from the given 6. You forgot the force equation. Use it to eliminate W from the torque equation, then find the ratio.
If you post another photo, please make sure that there is plenty of light and use a dark pen to increase contrast. The rotation doesn't bother me because I can turn my laptop 90o to look at it. :smile:
Likes Helly123
That is what I mean by choosing an axis.
Yes, I know. I wanted to clarify the point (pardon the pun) for OP who wrote in post #5, "I use the table surface as the axis."
Ok, but I thought I already clarified that in post #6.
You did ... and I missed it.
I don't understand.. using right hand rule. Which direction W torque go?
As usual, if the fulcrum is to the left of a vertical line passing through the point of application of W, the torque is counterclockwise; if the fulcrum is to the right of the line, the torque is clockwise.
On edit: This is incorrect. Please see my correction below in post #23.
W is more like at the middle btw. And W force is going down
Look at your drawing in post #12. Imagine a vertical line through the fulcrum. Is W to the right, to the left or right on the vertical line?
On Edit: I just realized that I mistakenly interchanged my directions for down forces. The correct rule is Fulcrum to the left, force down, torque clockwise. Fulcrum to the right, force down, torque counterclockwise. Sorry about the confusion.
Likes Helly123
It is ok. Kind more make sense now. Thank you
Um.. How about choosing A as the axis?
You can choose any point as your axis, A, B, O, G or any other point you wish. If the system is in static equilibrium the sum of torques acting on it about all axes will be zero. It will not suddenly acquire a net torque because of your choice of axes. Therefore, it makes sense to pick an axis that makes the torque calculation as easy as possible to you. If you pick O, you have to calculate three torques, but the lever arms are easier to find; if you pick A, B or G, you only have two torques to calculate, but finding the lever arms may be a bit more involved. Any choice will give the same answer.
yes. so, the torque for ##F_A## = 0
left is torque ##F_B## and torque W
lever arms for torque ##F_B## = 2Lcos##\theta##
lever arms for W = Lsin##\theta##
both torques have the same directions.
sigma torque = 0
-torque ##F_B## = torque W
-##F_B##* 2Lcos##\theta## = ( ##F_B + F_A##)* Lsin##\theta##
( ##F_B ) / (F_A##) = ( -2Lcos##\theta## - Lsin##\theta## ) / Lsin##\theta##
( ##F_B ) / (F_A##) = ( -2cos##\theta## - sin##\theta## ) / sin##\theta##
( ##F_B ) / (F_A##) = ( -2##\theta - tan\theta ) / tan\theta##
which is wrong sir?
The distance from A to G where gravity acts is ##L\sqrt{2}##, not ##L##. Also the appropriate trig function should involve ##45^o-\theta##. Make a drawing and you will see.
Can you elaborate it? Why there is 45-##\theta## ? (Sorry for the pic)
Look at the picture below. (I just noticed that my drawing has points A and B interchanged, sorry). You want the angle ##\varphi## that is formed with distance AG (red line) and the perpendicular to it (dotted red line). Then the torque due to the weight is ##\tau_W=W (AG) \cos\varphi##. To find ##\varphi## note that when the table is rotated back to horizontal, the acute angle between the weight and AG becomes 45o. Apply similar reasoning to your picture which has points A and B interchanged. Hint: The answer will be slightly different from this picture.
Likes Helly123
1. What is the purpose of finding the forces on a table in a tilted position?
The purpose of finding the forces on a table in a tilted position is to understand the distribution of weight and pressure on the table. This information can be useful in determining the stability and strength of the table, as well as identifying potential areas of weakness.
2. How do you calculate the forces on a tilted table?
The forces on a tilted table can be calculated using Newton's laws of motion and the principles of statics. This involves identifying all the external forces acting on the table, such as the weight of objects on the table and any applied forces, and then analyzing the forces in different directions to determine the net force and its direction.
3. What factors can affect the forces on a tilted table?
The forces on a tilted table can be affected by various factors, including the weight and distribution of objects on the table, the angle of tilt, the type and strength of materials used in the table, and any external forces such as wind or vibrations.
4. How can the information about forces on a tilted table be used?
The information about forces on a tilted table can be used to design and build stronger and more stable tables, as well as to determine the maximum weight that a table can safely hold. It can also be useful in identifying potential hazards or areas of weakness in existing tables.
5. Are there any safety considerations when lifting a table in a tilted position?
Yes, there are some safety considerations when lifting a table in a tilted position. It is important to ensure that the table is properly balanced and supported to prevent it from tipping or collapsing. It is also important to use proper lifting techniques and to have enough people to safely lift and move the table.
