Homework Help: Find the Fourier series
  1. Aug 22, 2011 #1
    The function f has period 4 and is such that
    f(x)=2+x, -2<x[itex]\leq0[/itex]
    f(x)=2, 0<x<2
    Sketch the graph of f for x∈[−4, 4] and obtain its Fourier series.
    2. Relevant equations
    3. The attempt at a solution
    Okay so I've pretty much sketched the graph, but I've been thrown by the 2+x and I'm not sure what to do from this point onwards.
    So a0=[itex]\frac{1}{2}[/itex][itex]\int^{2}_{0}2dx[/itex]=2
    an=[itex]\frac{1}{2}[/itex][itex]\int^{2}_{0}2*cosnxdx[/itex]
    So
    an=[itex]\frac{sin2n}{n}[/itex]
    And
    bn=[itex]\frac{-(cos(2n)-1)}{n}[/itex]
    Am I on the right lines...?
  3. Aug 22, 2011 #2
    LCKurtz
    No, you aren't. You are given one period of a function whose period is 4. That is a two piece function defined on (-2,2). If you have graphed it you will know that it is neither even nor odd so you may not use the half-range formulas for the coefficients. The formula for an in this problem is
    [tex]a_n = \frac{1}{2}\int_{-2}^{2}f(x)\cos(\frac{n\pi}{2}x)\, dx[/tex]
    and similarly for bn. You have to break these intgrals up into (-2,0) and (0,2) and use the appropriate formula for f(x) in each.
  4. Aug 22, 2011 #3
    Oh god, I'm an idiot. Thank you for that! Can't believe I did that.
    So I now have
    an=[itex]\frac{1}{2}[/itex][itex]\int^{0}_{-2}(2+x)cos(\frac{n\pi}{2})xdx[/itex]+[itex]\frac{1}{2}[/itex][itex]\int^{2}_{0}2cos(\frac{n\pi}{2})xdx[/itex]
    = [itex]\frac{4sin(n\pi)}{n\pi}[/itex]
    and bn= [itex]\frac{-2(ncos(n\pi))(\pi-sin(n\pi))}{n2\pi2}[/itex]
  5. Aug 22, 2011 #4
    Sorry, I forgot to take the sines and cosines out
    an=[itex]\frac{2}{n^{2}\pi^{2}}[/itex]
    and
    bn= 0
    Is what I've got which I HOPE is correct.
    This would make the Fourier series
    f(x)=[itex]\frac{3}{2}[/itex]*[itex]\sum^{\infty}_{n=1}\frac{2}{n^{2}\pi^{2}}cos(\frac{(n\pi)x}{2})[/itex]
  6. Aug 22, 2011 #5
    LCKurtz
    That can't be correct because your original f(x) is neither even nor odd, and this answer is an even function. You can't have all the bn be zero.
  7. Aug 23, 2011 #6
    I keep reaching different answers for my an and bn
    My latest answers are
    an= [itex]\frac{2(n+1)}{n^{2}\pi^{2}}[/itex]
    and
    bn= [itex]\frac{2(n\pi^{2}+\pi^{2}-1)}{n\pi}[/itex]
  8. Aug 23, 2011 #7
    LCKurtz
    Those are both wrong and you haven't calculated a0. Here's what you should get for your constants:
    [tex]a_n=\frac{(-1)^{n+1}+1}{\pi n^2}[/tex]
    [tex]b_n=\frac{(-1)^{n+1}}{n}[/tex]
    [tex]a_0=2-\frac{\pi}{4}[/tex]
    Keep trying.
  9. Aug 23, 2011 #8
    vela
    Staff Emeritus
    Education Advisor
    Those aren't correct. You should get
    \begin{align*}
    a_n &= (1+(-1)^{n+1})\frac{2}{n^2\pi^2} \\
    b_n &= (-1)^{n+1}\frac{2}{n\pi}
    \end{align*}
    I think you dropped a factor of pi somewhere, LCKurtz.
  10. Aug 23, 2011 #9
    I got a0= [itex]\frac{3}{2}[/itex]
    Because I thought the formula was
    [itex]\frac{1}{2L}[/itex][itex]\int^{L}_{-L}f(x)dx[/itex]
    and L is 2 so
    a0= [itex]\frac{1}{4}[/itex][[itex]\int^{0}_{-2}(2+x) dx + \int^{2}_{0}2 dx][/itex]
    Which would give [itex]\frac{3}{2}[/itex]
  11. Aug 23, 2011 #10
    LCKurtz
    Yes, 3/2 is correct for a0. Vela's formulas for the coefficients are correct. I inadvertently used L = pi instead of L = 2 when I calculated the coefficients.
Loading...
