Find the integral
Find f(x) if:(a∈R)
$$f(x)=\int_0^{\frac{\pi}{a}}f(t)cos(at-2ax)dt+1$$
$$f(x)=\int_{a}^{b}f(t)dt=F(a)-F(b)$$
$$\int{udv}=uv-\int{vdu}$$
I tried to use the fundamental of calculus and integration by parts but they don't have answer. Because cos(at-2ax) confuses me.
Thank for helping
Answers and Replies
pasmith
1,772
439
Find f(x) if:(a∈R)
Thank for helping
The fundamental theorem may not help, since you don't know an antiderivative of [itex]f[/itex].
Instead use [itex]\cos(at - 2ax) = \cos(at)\cos(2ax) + \sin(at)\sin(2ax)[/itex] to obtain [tex]
f(x) = 1 + \cos(2ax)\int_0^{\pi/a}f(t)\cos(at)\,dt + \sin(2ax)\int_0^{\pi/a}f(t)\sin(at)\,dt.[/tex] Now set [itex]A = \int_0^{\pi/a} f(t) \cos(at)\,dt[/itex], [itex]B = \int_0^{\pi/a} f(t) \sin(at)\,dt[/itex] so that [itex]f(t) = 1 + A\cos(2at) + B\sin(2at)[/itex] and you can obtain a pair of simultaneous equations to be solved for [itex]A[/itex] and [itex]B[/itex].
Likes Hamal_Arietis
so that ##f(t)=1+Acos(2at)+Bsin(2at)f(t)=1+Acos⁡(2at)+Bsin⁡(2at)f(t) = 1 + A\cos(2at) + B\sin(2at) ##and you can obtain a pair of simultaneous equations to be solved for A and B.
Thanks, I understood. Another equation is:
$$f(t)=\int_0^{\frac{\pi}{a}}f(t)cos(at)dt+1=A+1$$
But we must find f(t), A, B while we have 2 equations?
Oh, I see:
$$A=Acos(2at)+Bsin(2at)$$
$$A(1-cos(2at))=Bsin(2at)$$
$$2Acos^2(at)=2Bsin(at)cos(at)$$
$$cos(at)(Acos(at)-Bsin(at))=0$$
So we have:
$$\int_0^{\frac{\pi}{a}}f(t)cos^2(at)dt=\int_0^{\frac{\pi}{a}}f(t)sin^2(at)dt \Rightarrow f(t)cos^2(at)=f(t)sin^2(at)\Leftrightarrow f(t)=0 ∨ at=\frac{\pi}{4}+k\pi (k∈Z)$$
So the answer is:
$$f(x)=\frac{\pi}{a}+1$$
Is this right?
Ray Vickson
Dearly Missed
10,706
1,728
Find f(x) if:(a∈R)
Thank for helping
Try looking at ##f'(x)## and ##f''(x)##, to see if ##f(x)## obeys a simple differential equation.
vela
Staff Emeritus
Education Advisor
14,662
1,292
Oh, I see:
Where did this come from?
$$\int_0^{\frac{\pi}{a}}f(t)cos^2(at)dt=\int_0^{\frac{\pi}{a}}f(t)sin^2(at)dt \Rightarrow f(t)cos^2(at)=f(t)sin^2(at)$$
No. You can't infer that because the two integrals are equal the two integrands are equal.
What pasmith suggested was you have an expression for f(t) in terms of A and B. Plug that into the expressions that define what A and B are and evaluate the integrals. You'll end up with two equations which you can solve for A and B.
Ray Vickson
Dearly Missed
10,706
1,728
Oh, I see:
So we have:
So the answer is:
Is this right?
No, it is not right. I suggest you go back and look at post #5.
Both equations are:
$$f(t)=A+1$$
$$f(t)=1+Acos(2at)+Bsin(2at)$$
So ##A=Acos(2at)+Bsin(2at)##
and I transfer it into:
$$\int_0^{\frac{\pi}{a}}f(t)cos^2(at)dt=\int_0^{\frac{\pi}{a}}f(t)sin^2(at)dt$$
I try to find f'(x) by the fundamental of calculus before but it don't have answer
Ray Vickson
Dearly Missed
10,706
1,728
You can find a formula for
$$\frac{d}{dx} \int_a^b h(x,t) \, dt$$
It has nothing to do with the fundamental theorem of calculus.
Likes Hamal_Arietis
Sorry, I don't understand your idea. Can you give me some document about it?. This problem is an examination for high school students to entrance university. I have learned that:
If ##F(x)=\int_a^xf(t)dt## then:
$$\frac{d}{dx}F(x)=\frac{d}{dx}\int_a^xf(t)dt=f(x)$$
vela
Staff Emeritus
Education Advisor
14,662
1,292
Both equations are:
$$f(t)=A+1$$
Where did this come from? Note the lefthand side depends on ##t##, but the righthand side is a constant. It doesn't look right to me.
You have ##f(t) = 1 + A \cos 2at + B \sin 2at## where ##A = \int_0^{\frac{\pi}{a}}f(t)\cos at\,dt##. Plug the expression for ##f(t)## into the definition of ##A## and evaluate the integral.
$$A=\int_0^{\frac{\pi}{a}}f(t)\cos at\,dt$$
$$A=\int_0^{\frac{\pi}{a}}( 1 + A \cos 2at + B \sin 2at)cos(at)dt$$
$$A=\frac{4B}{3a}$$
And $$B=\int_0^{\frac{\pi}{a}}( 1 + A \cos 2at + B \sin 2at)sin(at)dt$$
$$B=\frac{2}{a}+\frac{2A}{3a}=\frac{6+2A}{3a}$$
Then solve both equation:
$$A=\frac{24}{9a^2-8};B=\frac{18a}{9a^2-8}$$
Ray Vickson
Dearly Missed
10,706
1,728
$$A=\frac{4B}{3a}$$
Almost OK: the ##B##-equation should be
$$B=\frac{2}{a} - \frac{2A}{3a},$$
which changes the final solution a bit.
Likes Hamal_Arietis
Related Threads on Find the integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
