Find the limit of a sequence
given a geometric sequence sin(x),sin(2x), . . .
c) find for which values of x∈(0,π) this sequence converges and calculate its limit
|q|<1 or -1<q<1
Ok so in part a) and b) i calculated the quotient and found out that
q=sin2x/sinx
q=(2*cos(x)*sin(x))/(sin(x))
q=2*cos(x)
so know i tried to figure out for which values x will converge
|q|<1
-1<q<1
-1<2*cos(x)<1 /:2
-1/2<cos(x)<1/2
2π/3>x>π/3
which means that the sequence will converge when the angle is anywhere between 120° and 60°
However i'm unsure now how to continue to find the limit because I've never seen an example where the value x isin't exactly defined
could someone show me how this is done or give me some kind of a hit or check if I made a mistake somewhere inbetween
Thanks
Answers and Replies
PeroK
Insights Author
2021 Award
21,567
12,870
What makes you think that is s geometric sequence?
Also, you use both the terms series and sequence. Which is it?
I'm really sorry I made a mistake while translating the text into english.
Also it is written in the problem that this is a geometric sequence
HallsofIvy
41,847
969
And the sequence is sin(x), 2 cos(x)sin(x), 4cos^2(x)sin(x), 8 cos^3(x)sin(x), ... ?
Yes, the "geometric sequence a, ar, ar^2, ar^3, ... converges for -1< r< 1 and converges to a/(1- r). Here you are saying that a= sin(x) and r= 2cos(x).
PeroK
Insights Author
2021 Award
21,567
12,870
Perhaps there is a problem in translation, but clearly ##sin(nx)## is not in general a geometric sequence. Take ##x = \pi/2## for example.
Perhaps it will be better if I write the whole problem out not just the last step I'll try to do that right now
yes that's the sequence.
but woudn't that just give me the sum of all elements of the sequence?
Edit :
I asked my profesor if he could give me the solutions and he didn't have much time but I did get to take a picture if this helps in any way
so the solutions to 5 c)
are π/3 ≤ x < 2*π/3 --------- it is the same that I got but I don't know why there is an equal sign?
x=π/3 ----------- the limit is sqrt(3)/2
π/3 < x < 2*π/3 the limit is 0 <------------------- i get this because if -1< r< 1 the sequence converges to 0
Could someone explain the equal sign in the first inequality
PeroK
Insights Author
2021 Award
21,567
12,870
So, the question is: For which values of x does the geometric sequence converge:
##sinx, sinx(2cosx), sinx(2cosx)^2 \dots##
Well, I though if the series converges the sequence would converge as well.
Therefore I went ahead and wrote that |q|<1
PeroK
Insights Author
2021 Award
21,567
12,870
Many sequences converge when the corresponding series does not.
What about #q =1##?
Hmmm, now that you pointed it out if q=1 the limit of the sequence would simply be sin(x)
Ray Vickson
Dearly Missed
10,706
1,722
Is the sequence
sin(x), sin(2x), sin(3x), sin(4x), sin(5x), ...
or is it
sin(x), sin(x), sin(4x), sin(8x), sin(16x), ....?
the sequence is
sin(x), sin(x)*2cos(x), sin(x)*(2*cos(x))2, sin(x)*(2*cos(x))3, sin(x)*(2*cos(x))4, . . .
What about #q =1##?
i think I get it now
the sequence
an=sin(x)*(2*cos(x))n-1 will converge when either |2*cos(x)|<1--------- when that is true the sequence will converge to 0
or when 2*cos(x)=1
2*cos(x)>1 this is not possbile because a limit would not exist here
2*cos(x)=-1 because the limit doesnt exist here either
am I correct about this?
PeroK
Insights Author
2021 Award
21,567
12,870
the sequence
or when 2*cos(x)=1
Yes.
Related Threads on Find the limit of a sequence
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
