Find the limit
  1. Oct 8, 2011 #1
    Find the lim of [itex]\frac{\sqrt{6-x}-2}{\sqrt{3-x}-1}[/itex]when x approaches 2, without using L'hopital rule or the definition.
    2. Relevant equations
    3. The attempt at a solution
    I try to multiply both the numerator and the denominator to get [itex]\frac{(\sqrt{6-x}-2)(\sqrt{3-x}-1)}{2-x}[/itex], but when I substitute x = 2, the term becomes undefined.
    Any suggestion? Thanks.
    I am thinking of de'rationalize' the rational surd fraction, but nothing works.
  3. Oct 8, 2011 #2
    arildno
    Dearly Missed
    1. First off:
    There should be a "+1" rather than "-1" in the remaining factor after you myliplied both denominator and numerator with the 2conjugate".
    2. secondly:
    do the same "conjugate trick", with the surd expression that is contained in the numerator.
  4. Oct 8, 2011 #3
    Oops, sorry. Now I have
    =[itex]\frac{(\sqrt{6-x}-2)(\sqrt{3-x}+1)}{(\sqrt{3-x}-1))(\sqrt{3-x}+1)}[/itex]
    =[itex]\frac{(\sqrt{6-x}-2)(\sqrt{3-x}+1)}{2-x}[/itex]
  5. Oct 8, 2011 #4
    arildno
    Dearly Missed
    Correct.
    Now do the same trick with the other surd expression.
  6. Oct 8, 2011 #5
    Yay, I get it. I multiply by another conjugate and eventually the (2-x) term will cancel out. Then I will get 2/4 which is equal to 1/2. Thanks so much for the help. :)
    =[itex]\frac{(\sqrt{6-x}-2)(\sqrt{3-x}+1)(\sqrt{6-x}+2)}{(2-x)(\sqrt{6-x}+2)}[/itex]
    =[itex]\frac{(\sqrt{3-x}+1)(2-x)}{(2-x)(\sqrt{6-x}+2)}[/itex]
    =[itex]\frac{\sqrt{3-x}+1}{\sqrt{6-x}+2}[/itex]
    So if I replace x = 2, I will get 2/4 = 1/2. :)
  7. Oct 8, 2011 #6
    arildno
    Dearly Missed
  8. Oct 8, 2011 #7
    Another question:
    Find the limit of [itex]\frac{sin^{-1}x}{x}[/itex] when x approaches 0.
    The answer given is 1.
    Seems like I can't express arcsin explicitly. Any clue on how to start? :)
  9. Oct 8, 2011 #8
    Can I use the series expansion?
    =[itex]\frac{x+\frac{X^3}{6}+\frac{3x^5}{40}+...}{x}[/itex]
    =1+[itex]\frac{x^2}{6}+\frac{3x^4}{40}+...[/itex]
    Then I can get limit = 1 when I substitute x = 0.
    Can we get the same answer without using the series expansion thingy?
  10. Oct 8, 2011 #9
    arildno
    Dearly Missed
    Or, you could make the substitution x=sin(u), which is valid in the neighbourhood of x=0.
