Homework Help: Find the mass of ethyl alcohol
  1. Jun 22, 2009 #1
    What is the initial temperature of copper if, 11 g aluminum at 200 C and 21 g of copper are dropped into 46 cm^3 of ethyl alcohol at 15 C. The final temperature of the system is 22 C.
    2. Relevant equations
    Q=McT
    3. The attempt at a solution
    My work : Qal+Qcu+Qea=0, and solved for the intial temperature. I got -130 C which was wrong. To find the mass of ethyl alcohol, i used volume and density. Volume is 790 kg/m^3
  3. Jun 22, 2009 #2
    mgb_phys
    Re: Calorimetery
    Try converting everything into the same units (eg kg)
  4. Jun 22, 2009 #3
    Re: Calorimetery
    i converted everything and got this forumla
    m1 * s1 * t1 + m2 * s2 * t2 + = m1 * s1 * tf + m2 * s2 * tf + m3 * s3 * tf
    m1= aluminum
    m2=coppper
    m3=ethtyl alcohol,
    i just cant get the write answer.
  5. Jun 22, 2009 #4
    mgb_phys
    Re: Calorimetery
    In Q=mcT , 'T' is the change in temperature
  6. Jun 22, 2009 #5
    Re: Calorimetery
    yea, i took that into account, so i did heat loss=heat gained, and the heat lost was by the aluminum, and i know the ethyl alcohol gained heat, but im not sure what side the copper would go on
  7. Jun 22, 2009 #6
    mgb_phys
    Re: Calorimetery
    Al goes from 200 to 22
    Cu goes from T to 22
    Ethyl goes from 15 to 22
    So
    m_al * c_al * (200-22) + m_cu * c_cu * ( T-22) + m_eth * c_eth * (15-22) = 0
