Find the particle
  1. Dec 11, 2006 #1
    Where is the particle most likely to be found given the wavefunction in the diagram
    Also the wavefunction decays exponentially as x goes to infinty
    2. Relevant equations
    well the wavefunction is the probability amplitude
    the square modulus of the wavefunction gives the probability desnity
    and the square modulus times delta x gives the probability of finidng a particle bewtween x and x + delta x
    3. The attempt at a solution
    i think it is most likely to be fond where the probability amplitude is maximum because at those regions the particle has maximum proabiltiy of being found
    is this correct??
    thanks for your help!
      File size:
      10 KB
      133
  3. Dec 11, 2006 #2
    OlderDan
    Yes
    In 3-D you do have to be careful with radial wave funcions. The usual thing is to plot rR(r) because R(r) itself is not sufficient to find the most likely r. That's bcause a particle can be found at one value of r and be anywhere in a shell of radius r and thickness dr. The volume of the shell increases in proportion to the area of a sphere, or as r²
