Find the potential difference of point b relative to point a
In summary, to find the potential difference between point a and point b, you need to take into account the voltages across the resistors and the polarity of the batteries. By using Kirchhoff's laws and knowing the direction of the current in each branch, you can determine the polarity of the voltages across the resistors. The voltage at point a can be found relative to point b by subtracting the voltage at point b from the voltage at point a.
Snazzy
470
Find the potential difference of point b relative to point a.
I found out that E1 = 18V and E2 = 7V but I don't know where to go from there.
Voltages are measured with respect to some reference. What did you use for your reference to get E1 = 18V and E2 = 7V? If these were correct, then the potential DIFFERENCE would be 18-7 = 11 volts, but it isn't.
All you need to do is look at the top branch. The current in the branch is given, so the voltages across the two resistors are known. Combine that knowledge with the value of the voltage source in the branch, and you should be able to get the DIFFERENCE in potential (voltage) between point a and point b.
Ok, so the potential difference across the 1.00 Ohm resister is 1V, so the potential at A would be 20-1 = 19V, and then the potential difference across the 6.00 Ohm resistor is 6V, so then the potential at b would be 0+6 = 6V.
So then Vb - Va = -13V?
Also, how would I do that question? I've deduced the currents in each branch.
The -13 volts is correct.
When you say "...so the potential at A would be 20-1 = 19V...", you are using the unlabeled point between the 20 volt battery and the 6 ohm resistor as your reference (ground?). You didn't mention it, but you should be aware when you make such a choice. Remember that voltage is always a relative thing; you must measure or compute with respect to some reference point. I would have chosen point a as my reference because the question wants to know the voltage at point b RELATIVE to point a. This makes point a the logical reference. But since the question wants to know the DIFFERENCE in voltage between point a and point b, any point in the circuit can be the reference because it will fall out of the equation when the difference is taken.
For the next problem, if you know the currents, then moving from point a to point b, multiply the current in the top branch by the 3 ohm resistor to find the voltage across that resistor. Multiply the current in the second branch by the 4 ohm resistor to find the voltage across that resistor. Then the voltage between point a and point b will be the sum of the voltages across the 3 and 4 ohm resistors, taking into account the polarity of each voltage.
Still a bit lost. The current in the top branch is 0.4A, which means if I multiply by the resistance, the potential difference across the 3 Ohm resistor is 1.2V.
The current in the middle branch is 1.6A, which means if I multiply by the resistance, the potential difference across the 4 Ohm resistor is 6.4V.
Now how do I take the polarity of the voltages into account? The voltages of the batteries or the voltage differences?
You've got take into account polarities of batteries and also voltages across resistors. You need to know the direction of the current in each branch to determine the polarity of the voltage across the resistors. Then end of the resistor where the current enters is by convention positive.
Oh okay. The current in the top branch is traveling from the left of A to the right of the 3 Ohm (from what I found using Kirchhoff's laws), so then at point A, the polarity is positive. And the current is traveling from the right of the 4 ohm resistor to the left of B (again, from what I found using Kirchhoff's law), so then the polarity at B is negative.
So then if I'm trying to find the potential at point A, relative to B, Va - Vb = 1.2 - (-6.4) = 7.6?
1. What is potential difference?
Potential difference is the difference in electric potential between two points in an electric field. It is a measure of the work needed to move a unit of charge from one point to another, and is typically measured in volts.
2. How is potential difference calculated?
Potential difference can be calculated by dividing the work done in moving a charge between two points by the amount of charge moved. In mathematical terms, it is expressed as V = W/Q, where V is the potential difference, W is the work done, and Q is the amount of charge moved.
3. What is the unit of measurement for potential difference?
The unit of measurement for potential difference is the volt (V). It is named after Italian physicist Alessandro Volta, and is equivalent to one joule per coulomb.
4. How is potential difference different from voltage?
While voltage and potential difference are often used interchangeably, they are not exactly the same. Voltage refers to the electrical potential difference between two points, while potential difference is the difference in electric potential between those two points. In other words, voltage is a specific type of potential difference.
5. How is potential difference related to electric current?
Potential difference is directly related to electric current. In fact, it is one of the main driving forces for the flow of electric current. A higher potential difference between two points means there is a greater difference in electric potential, which leads to a higher rate of flow of electric charges (i.e. electric current).
  • Electrical Engineering
  • Classical Physics
