Angela_vaal
- 59
- 1
A 1.40 kg block slides with a speed of 0.885 m/s on a frictionless horizontal surface until it encounters a spring with a force constant of 637 N/m . The block comes to rest after compressing the spring 4.15 cm.
Part A
Find the spring potential energy, U, the kinetic energy of the block, K, and the total mechanical energy of the system, E, for compressions of 0 cm.
Part B
Find the spring potential energy, U, the kinetic energy of the block, K, and the total mechanical energy of the system, E, for compressions of 1.00 cm.
Part C
Find the spring potential energy, U, the kinetic energy of the block, K, and the total mechanical energy of the system, E, for compressions of 2.00 cm.
Part D
Find the spring potential energy, U, the kinetic energy of the block, K, and the total mechanical energy of the system, E, for compressions of 3.00 cm.
Part E
Find the spring potential energy, U, the kinetic energy of the block, K, and the total mechanical energy of the system, E, for compressions of 4.00 cm.
Potential energy= 1/2Kx2
Kinetic energy=1/2mv2
Mechanical energy=KE+PE
I got the first answer correct using these equations. However, when I use these equations for part B I get them wrong. For example, this is what I did.
part B) PE=(.5)(.01m)(.0415m)2 =8.6x10-6J
KE= (.5)(1.40kg)(.885m/s)2 = .548 J
ME= .548J+8.6x10-6 = .548 J
I don't know what I am doing wrong if someone can please explain I would appreciate it! Also, I have seen in other examples that the KE is supposed to change with each compression. How? if the mass and the velocity remain the same?
