teng125
- 416
for x^2 +4x +5=0 ,may i know how to compute the roots incomplex form??
the answer is -2+j and -2-j
thanx
thanx
To solve for the roots of a quadratic equation in complex form, you can use the quadratic formula. This formula is x = (-b ± √(b^2 - 4ac)) / 2a, where a, b, and c are the coefficients of the quadratic equation ax^2 + bx + c = 0. Simply plug in the values of a, b, and c from the equation x^2 + 4x + 5 = 0 to find the roots.
Having complex roots means that the solution to the quadratic equation is not a real number, but instead involves the imaginary unit i = √(-1). Complex roots come in the form of a + bi, where a and b are real numbers and i is the imaginary unit. In the equation x^2 + 4x + 5 = 0, the complex roots are -2 + i and -2 - i.
No, you cannot graph complex roots on the Cartesian plane. The Cartesian plane is used for graphing real numbers, and complex roots involve imaginary numbers. Instead, you can graph complex numbers on the complex plane, which uses the horizontal axis for the real part and the vertical axis for the imaginary part.
Yes, there is a difference between finding the roots of a quadratic equation in real form vs. complex form. In real form, the roots will always be real numbers. In complex form, the roots can be a combination of real and imaginary numbers. Additionally, the quadratic formula used to find complex roots will include the ± symbol, indicating that there will be two possible solutions.
We may need to find the roots of a quadratic equation in complex form for various reasons. One example is in electrical engineering, where complex numbers are used to represent electrical quantities. In this field, finding complex roots is essential for solving certain circuit problems. Complex roots also have applications in other areas of physics and engineering.
