Find the total kinetic energy
  1. Mar 22, 2006 #1
    A block of mass m1 = 2 kg rests on a table with which it has a coefficient of friction µ = 0.75. A string attached to the block passes over a pulley to a block of mass m3 = 4 kg. The pulley is a uniform disk of mass m2 = 0.4 kg and radius 15 cm. As the mass m3 falls, the string does not slip on the pulley.
    Pic Attatched
    I have the free body diagram
    Force of friction - T1 = Rotational energy of disk = mg-T3
    I am trying to find T1, Acceleration and T3. do i need to find the total kinetic energy first of the system or can i somehow do it my way?? Thanks
    Edit: Sorry about the title
  3. Mar 22, 2006 #2
    Let's look at this. I assume its like the table situation, one mass attached to another and a pulley on the corner :-|
    Draw 2 force-body diagrams for each.
    Go ahead and label everything, force of friction, normal force, weight, and tension :-) That should simplify...
    Note that the sum of all forces on a SINGLE force-body diagram must be zero...
    Start with the one that falls to find tension, then figure out force friction, acceleration based on net force of the force-body diagram on block.
    Hope that simplifies it a bit...?
  4. Mar 22, 2006 #3
    so i dont need to worry bout kinetic and all that other stuff
  5. Mar 23, 2006 #4
    Any help please, i tried ur idea and it is not the answer
  6. Mar 23, 2006 #5
    Staff Emeritus
    Okay, basically, you have a number of forces acting. You have the frictional force of m1 and the moment of inertia of the pully which will oppose the force generated by the weight of m3. Can you write down a formula to represent those variables? Don't forget, the tension is constant throughout the whole string.
  7. Mar 23, 2006 #6
    okay then, if tension is constant then why do i have to figure the tension for 1 and tension for 3? Are they basically the same answer.
    So what u are trying to say is
    Frictional Force - (moment of intertia of pully+Mass of M3*9.8) = 0
    and just solve for Velocity, then that will help me get Acceleration?
  8. Mar 23, 2006 #7
    Staff Emeritus
    No, what I'm saying is that the frictional force and the moment of inertia of the pully will oppose the weight of m3.
    No, using forces will give you the acceleration. I will start you off.
    [tex]m_{3}g = F_{friction} + F_{pully}[/tex]
    Friction is given by [itex]Fr = \mu R = \mu mg[/itex]. The moment of inertia of a disc is given by [itex]\frac{1}{2}mr^2[/itex].
    Can you construct a formula from this information?:smile:
  9. Mar 23, 2006 #8
    i am soo sorry but i am lost, how is this formula going to help me find Acc or even tension. i am not getting where you want me to head. WIll torque get involved in this problem
  10. Mar 23, 2006 #9
    Staff Emeritus
    Its no problem, I'm not very good at explaining this type of question. For sum reason they always seemto confuse me :confused: It's probably best if we wait for someone else to asnwer you, because I'll end up confusing myself :blushing: Sorry I've not been much help :shy:
  11. Mar 23, 2006 #10
    Staff Emeritus
    I may have figured it out. Here's my take on it;
    As the particles are connected the accleration must be equal, therefore
    [tex]a = \frac{\Sigma F}{\Sigma m}[/tex]
    Can you sum the forces?
  12. Mar 23, 2006 #11
    nope that aint doin it, and i did some all forces + masses. :( I hate these kind of problems
  13. Mar 26, 2006 #12
    i still haven't figured it out, any help please. Does this involve torque cause i tried. Thanks alot
