Homework Help: Find the total resistance
  1. May 12, 2013 #1
    9.15
    a) Each box has the restistance 1 Ohm. Find the total resistance between 1) A-B 2) A-D 3) B-C
    b) Find I (electric current(?)) from A-D if you put a battery from B-C
    c) Find I on the Ammeter and the direction (the lower picture)
    http://sphotos-h.ak.fbcdn.net/hphotos-ak-prn1/v/954585_10151577257929660_1441841441_n.jpg?oh=536e2a504401f9beebed972302e56839&oe=51920295&__gda__=1368521085_3193921ab59c05a6069ec6b2519d2702
    9.126
    a) Use Kircchofs 2nd law on ABED to show that I3 ) 0,5A
    b) Explain how I2 + I5 = 2A. Use Kirchhoffs 2nd law on BEFC to find another equation for uknown I2+I5
    c) Find I1 and I4
    d) Find the resistance R.
    2. Relevant equations
    Kirchoff's circuit law is relevant
    3. The attempt at a solution
    9.15
    a) 1) Thought it would be just 1 ohm but it's supposed to be 0,63 2) I used 1/Rtotal = 1/R + 1/R + R which means 2+1 = 3 which is wrong while it's supposed to be 0,5.
    This makes the rest pretty complicated to solve.
    9.126
    I used Kirchoffs law and found following formulas but not sure if it's supposed to be solved as
    5 unknowns while we've only been into 3.
  3. May 12, 2013 #2
    tiny-tim
    Welcome to PF!
    Hi MJay! Welcome to PF! :smile:
    You need to use all the paths from A to B :wink:
    erm :redface:
    calculate it again! :smile:
  4. May 12, 2013 #3
    Hey thanks :)
    I tried a different method now:
    1/R = 1/(AC+CD) + 1/AD
    which gives 2/3 then I insert it in 1/R= 1/(2/3) + 1/(AB+BD) Am I on the right way?
  5. May 12, 2013 #4
    tiny-tim
    Hi MJay! :wink:
    (this is part 2)
    Correct :smile:
    (But your notation is terrible, and I suspect is misleading you …
    you can't just call everything R, and expect not to make mistakes :redface:)
    nooo
    think again :smile:
  6. May 12, 2013 #5
    Yeah understand but it get's so messy while I'm doing this in the way we learned it in school which might get confusing also, I'm not sure what way I should put it. But I have no clue or book to help me out, as this is the toughest exercise (marked with 2**).
Have something to add?
Draft saved Draft deleted
