Homework Help: Find this limit
  1. May 24, 2013 #1
    utkarshakash
    [itex]\stackrel{lim}{x→0} \left( \dfrac{1^x+2^x+......n^x}{n} \right) ^{1/x}[/itex]
    2. Relevant equations
    3. The attempt at a solution
    Let the quantity inside the bracket be represented by t.Rewriting
    [itex](1+t-1)^{\frac{1}{t-1}.(t-1).\frac{1}{x}} \\
    e^{(t-1)/x} \\
    \stackrel{lim}{x→0} \left( \dfrac{1^x+2^x+......n^x-n}{nx} \right)[/itex]
    Using L Hospital's Rule
    [itex]\stackrel{lim}{x→0} \left( \dfrac{x(ln1+ln2....ln n)}{n} \right)[/itex]
    Now if I put x=0 I get limit as e^0 = 1. But this is not the correct answer.
  3. May 24, 2013 #2
    if n= 1 our answer is as 1x = 1.
    Take the ln of the expression. Then we get:
    limx->0 ln((1x+...+nx)/n)/x
    If we plug in x = 0 we get ln(1)/0 = 0/0 so we can use L'hopital's rule getting as d/dx x = 1:
    limx->0 n/(1x+..._nx) * (ln(1)1n+...+ln(n)nx)/n =
    limx->0 (ln(1)1x+...+ln(n)nx)/(1x+...+nx).
    This is continuous at 0 so we can plug in x=0 to get:
    (ln(1) + ... + ln(n))/(1+...+1) = (ln(1) + ... + ln(n))/(n).
    So the original limit is exp((ln(1) + ln(2) ... + ln(n))/n)
    edit: checked with matlab this is right.
  4. May 24, 2013 #3
    Ray Vickson
    You have a limit of the form
    [tex] \lim_{x \to 0} \left( \frac{f_n(x)}{n}\right)^{1/x},\\
    f_n(x) = \sum_{i=1}^n i^x [/tex]
    Never mind l'Hospital; just look at the form of ##f_n(x)## for small |x|, then use some familiar limit results.
  5. May 24, 2013 #4
    utkarshakash
    I can't understand this step. Please tell me how you have differentiated the numerator?
  6. May 25, 2013 #5
    What's the derivative of ##a^x## w.r.t x, where a is some constant?
  7. May 25, 2013 #6
    I just canceled the n's. In latex:
    [itex]\frac{n}{1x+..._nx} \frac{ln(1)1n+...+ln(n)nx}{n}[/itex]
  8. May 25, 2013 #7
    [itex]\frac{n}{1^x+...+n^x} \frac{ln(1)1^n+...+ln(n)n^x}{n} = \frac{ln(1)1^n+...+ln(n)n^x}{1^x+...+n^x} [/itex]
  9. May 25, 2013 #8
    Approach 1: Take natural logarithm on both sides as, ln y = lim x->0 f(x).. Then you apply L' Hospital's Rule.
    Approach 2: Write the given limit in the form of lim n→0 (1+n)1/n = e and then evaluate accordingly.
  10. May 25, 2013 #9
    utkarshakash
    x lna
  11. May 25, 2013 #10
    dextercioby
    No, it's ln a times a^x.
  12. May 25, 2013 #11
    No.
    dextercioby has already pointed out the correct derivative. Redo it.
  13. May 25, 2013 #12
    utkarshakash
    Thanks for pointing out.
  14. May 25, 2013 #13
    utkarshakash
    Can you type in the exact command that you used to find limit in matlab? It seems my command is giving me incorrect result.
Have something to add?
Draft saved Draft deleted
Loading...
