Homework Help: Find time to evacuate compressed air tank (conceptual verification)
  1. Apr 1, 2012 #1
    This is a first-order differential equation problem involving a changing fluid density and changing tank pressure.
    Tank contents: Nitrogen
    Tank pressure: 390 psig
    Temperature of compressed nitrogen: 0 C
    Atmospheric volume = infinity
    Atmospheric pressure = 14.7 psi
    Atmospheric temperature = 0 C
    2. Relevant equations
    Use the following two equations
    1. Bernoulli's compressible fluid equation (neglecting gravitational potential): (v^2)/2+(γ/γ-1)*(p/ρ) = constant
    2. Mass flow rate for an ideal compressible gas: mflchk.gif
    3. The attempt at a solution
    I am trying to set up a DE in order to solve for the time to evacuate the tank from 390 psig to atmospheric pressure. Pretty standard conservation of mass problem... I thought about treating it similarly to a volume flow rate tank drain problem (i.e. A*(dh/dt) = -a*2gh), however, the mass flow rate in this case involves compressible fluid, where exit velocity and density vary with time.
    Any ideas would be very helpful! Thanks
Draft saved Draft deleted
