Find Vertical Displacement
Hi everyone, I'm a programmer, I'm doing a program for the simulation of some experimental data, the data is recorded by a device and that the register is the acceleration components along the (x, y, z), time (starting from 0, and aumentanto of each recording delta t), orientation (azimuth, roll, pitch),
my goal is to be able to extrapolate a graph (elevation, time), the data is recorded by a device inside a passenger compartment, with the y-axis pointing upwards. I read a lot about projectile motion, I think it's what I have to simulate substantially.
So for the calculation of the elevation, I would have thought to apply this formula:
y = Viy * t + 0.5 * aiy * t2
I thought to derive the speed through the Euler method, since dispose of acceleration and time data.
From this speed I should now extrapolate the vertical and horizontal speed, and if I understand correctly, the formula should be:
Viy =Vi * sin (Φ), the problem for me is to calculate precisely the angle Φ.
There is a way to calculate this angle?
scottdave
Insights Author
568
Your formula to calculate position [ y = Viy * t + 0.5 * aiy * t² ] is correct only while the acceleration is constant.
It sounds like your device will be collecting acceleration data (which potentially is changing). You could approximate that the acceleration is roughly constant during a small time period Δt, and get an approximation to the solution.
I am not sure what the angle Φ is representing here, to be able to comment on it. Does your device have a datasheet which explains the measured values? That could be helpful.
FactChecker
2018 Award
4,719
1,613
If you are only interested in elevation, then pitch is ##\phi##
Want to reply to this thread?
"Find Vertical Displacement" You must log in or register to reply here.
Related Threads for: Find Vertical Displacement
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
