Finding 2 unknow charges
  • Thread starter bobred
bobred
173
There are two opposite charges of equal magnetude, Q1 and Q2 separated by 4m. There is a central segment of 0.1m AB located centrally between the two charges AB. The electric field between AB can be taken as uniform. An electron is released with negligable speed at A and passes B 0.015 s later. Find the magnitude and sign of both Q1 and Q2.
[tex]s=ut+\frac{1}{2}at^{2}[/tex]
[tex]F_{el}=am_{e}[/tex] so [tex]a=\frac{F_{el}}{m_{e}}=\frac{q\mathcal{E}}{m_{e}}=\frac{-e\mathcal{E}}{m_{e}}[/tex]
[tex]F_{el}=k\frac{\left|q\right|\left|Q\right|}{r^{2}}[/tex] where [tex]k=\frac{1}{4\pi\epsilon_{0}}=8.988\times10^{9}\,\textrm{N}\,\textrm{m}^{2}\,\textrm{C}^{-2}[/tex]
[tex]\mathcal{E}=\frac{m_{e}a}{-e}[/tex]
[tex]m_{e}=9.109\times10^{-31}\,\textrm{kg}[/tex]
[tex]e=-1.602\times10^{-19}\,\textrm{C}[/tex]
Taking the positive x direction as the direction of the electron,
we can find the acceleration by
[tex]a=\frac{2s}{t^{2}}=\frac{2\times0.1\,\textrm{m}}{(0.015\,\textrm{s})^{2}}=888.89\,\textrm{m}\,\textrm{s}^{2}[/tex]
The electric field is
[tex]\mathcal{E}=\frac{am_{e}}{e}=\frac{888.89\,\textrm{m}\,\textrm{s}^{2}\times9.109\times10^{-31}\,\textrm{kg}}{-1.602\times10^{-19}\,\textrm{C}}=-5.054\times10^{-9}\,\textrm{N}\,\textrm{C}^{-1}[/tex]
The distance from Q2 to be is 1.95 m so the force at B is
[tex]F_{el}=q\mathcal{E}=-1.602\times10^{-19}\,\textrm{C}\times-5.054\times10^{-9}\,\textrm{N}\,\textrm{C}^{-1}=8.097\times10^{-28}\,\textrm{N}[/tex]
Using Coulumb's law and rearranging we find the charge
[tex]\left|Q\right|=\frac{F_{el}r^{2}}{k\left|q\right|}=\frac{8.097\times10^{-28}\,\textrm{N}\times(1.95\,\textrm{m})^{2}}{8.988\times10^{9}\,\textrm{N}\,\textrm{m}^{2}\,\textrm{C}^{-2}\times1.602\times10^{-19}\,\textrm{C}}=2.138\times10^{-18}\,\textrm{C}[/tex]
As the electron is travelling toward B we can tell that Q2 is +ve.
Does what I have done look ok?
Answers and Replies
gneill
Mentor
20,945
2,886
Why not take the midpoint between your charges as the place where the field is the average value, and find |Q| from that?
bobred
173
Good point
[tex]
\left|Q\right|=\frac{F_{el}r^{2}}{k\left|q\right|} =\frac{8.097\times10^{-28}\,\textrm{N}\times(2.00\,\textrm{m})^{2}}{8.988 \times10^{9}\,\textrm{N}\,\textrm{m}^{2}\,\textrm{ C}^{-2}\times1.602\times10^{-19}\,\textrm{C}}=2.249\times10^{-18}\,\textrm{C}
[/tex]
What I wanted to know was if my method was sound.
gneill
Mentor
20,945
2,886
Remember that there are two charges Q involved. Each will produce a force of magnitude Fel at the center point. Otherwise, your method looks good.
Suggested for: Finding 2 unknow charges
  • Last Post
