Finding A. Prob.
  • Thread starter Jbreezy
Jbreezy
582
The expoential distribution is given by
f(x) = 0 for x <0 and f(x) = Ae^-cx for x >= 0
Find A so that f(x) is a probability distribution. So all that I did was use the def.
I said A∫e^(-cx) dx = 1 from 0 to ∞ I integrated it I got that A/c = 1 so A = c.
So then the next question says find P(x <1) so I did ∫ce^-ct dt = -e^(-ct) between [0,1] so I'm just confused because I have c still it isn't like it's going to drop out. So I'm thinking I did something wrong. Should A be numerical? I don't see how . Thanks
Answers and Replies
brmath
329
34
Probably a statistician would know this, but I don't. What is P(x)?
Jbreezy
582
Probability. Idk. If they say find the probability that x <1 then you express it as P( x<1)
8,294
Since you aren't given a value for c, you aren't going to get a value for A that is a specific number. I don't see anything wrong in your work.
Jbreezy
582
OK. So report my answer for P( x<1 ) = ∫ce^-ct dt = -e^(-ct) between [0,1]
as 1/e^c
8,294
I'm not sure you're writing what you mean.
$$ \int e^{-ct}dt = -\frac 1 c \int e^{-ct} (-c dt) = -\frac 1 c e^{-ct} + C$$
For the definite integral you get 1/c. Note that I haven't included A, but if you multiply throughout by A, you get A/c. For that to be equal to 1, then A = c, which is what you had.
LCKurtz
Insights Author
774
as 1/e^c
That isn't correct. ##P(X<1)=\int_0^1 ce^{-cx}~dx## and you have left out the lower limit in your calculation.
Also, I think most texts define the exponential density function as ##\lambda e^{-\lambda x}## for ##x > 0## in the first place.
Jbreezy
582
This was my course pack. What do you mean it isn't right ? What isn't right? my answer for my integral 1/e^c?
I have the lower limit [0,1] what are you talking about.
Jbreezy
582
OH I see the lower limit missing. But what else isn't right?
Jbreezy
582
## P(X<1)=\int_0^1 ce^{-cx}~dx = 1-1/e^c ## Is this correct?
And is
## P(.5 < X<1.5)=\int_0^1 ce^{-cx}~dx = 1/e^c(0.5) - 1/e^c(1.5) ## correct?
I don't get what your saying is wrong LCKurtz
8,294
I think so. It's been a long time since I studied mathematical statistics, and I seem to recall that this is a Poisson distribution.
And is
## P(.5 < X<1.5)=\int_{.5}^{1.5} ce^{-cx}~dx ##
In general, ## P(a < X< b)=\int_a^b ce^{-cx}~dx ##, where a ≥ 0 and b ≥ a.
LCKurtz
Insights Author
774
Yes
And is
## P(.5 < X<1.5)=\color{red}{\int_0^1} ce^{-cx}~dx = 1/e^c(0.5) - 1/e^c(1.5) ## correct?
Put the correct limits on the integral and it will be.
Jbreezy
582
Oh I'm sorry. I just copied your tex and forgot to change it. It is OK on my paper.
Thanks
Ray Vickson
Dearly Missed
10,706
1,722
The value A = c is correct. Also:
[tex]P(X \leq v) = 1 - e^{-cv}, \: \: P(X > v) = e^{-cv}.[/tex]
These are used so often that if you plan to do more Probability in the future you should commit them to memory, along with
[tex] E X = \frac{1}{c}, \; \; \text{Var} X = \frac{1}{c^2}. [/tex]
BTW: the standard way of writing is to use ##e^{-cv}## rather than ##1/e^{cv}##. They are, of course, eqiuivalent, but the first way is used all the time by everybody, at least in works on probability.
Jbreezy
582
OH Ok cool thanks for the info ray.
Suggested for: Finding A. Prob.
  • Last Post
  • Last Post
  • Last Post
