Angular Speed of Electric Toothbrush Head: 795.49rad/s
  • Thread starter bigtymer8700
In summary, the conversation discusses the effectiveness of electric toothbrushes in removing dental plaque, specifically one model with a rotating head of 1.10cm in diameter that rotates back and forth through a 70.0 degree angle at a rate of 7600 times per minute. The conversation also mentions the average angular speed in each direction of the rotating head, with one person calculating it to be 795.49 rad/s but being told it is incorrect. Another person suggests it could be double that if the head rotates +70 degrees and then back to the start 7600 times per minute.
bigtymer8700
40
Electric toothbrushes can be effective in removing dental plaque. One model consists of a head 1.10cm in diameter that rotates back and forth through a 70.0 angle 7600times/min . The rim of the head contains a thin row of bristles. its asking me the average angular speed in each direction of the rotating head.
w=7600times/min(1min/60s)6.28rad/1rev= 795.49rad/s
but it says I am wrong what am i doing wrong?
It rotates through 70deg 7600 times /minute not a full circle.
so that's 70 * pi/180 radians in 60/7600 seconds.
It could also be double that if it means it goes +70deg then back to the start 7600 times a minute?
yea it would be double since its going back and forth thanks
1. What is the angular speed of an electric toothbrush head?
The angular speed of an electric toothbrush head is 795.49 radians per second.
2. How is the angular speed of an electric toothbrush head measured?
The angular speed of an electric toothbrush head is measured in radians per second using a rotational speed sensor.
3. Is the angular speed of an electric toothbrush head constant?
No, the angular speed of an electric toothbrush head can vary depending on the power setting and the resistance of the bristles against the teeth.
4. How does the angular speed of an electric toothbrush head affect its cleaning ability?
The higher the angular speed of an electric toothbrush head, the faster it can rotate and potentially provide a more thorough cleaning.
5. Can the angular speed of an electric toothbrush head be adjusted?
Yes, most electric toothbrushes have different power settings that can adjust the angular speed of the brush head.
  • Electrical Engineering
12K
