Finding Average Value on a Bounded Region: Parabola y = 4-x^2 and x-axis
In summary: The double integral of y is\int_{x=-2}^2 \int_{y= 0}^{4- x^2} y dydx= \int_{x=-2}^2 \left[\frac{y^2}{2}\right]_{y=0}^{4-x^2}dx= \int_{x=-2}^2 \frac{(4-x^2)^2}{2}dx= \frac{1}{2}\int_{x
tnutty
326
Find the average value of y on the region D that is bounded above by the parabola y = 4 - x2 and below by the x-axis.
Does this question makes sense?
I know the formula for the average values function :
1/(A(x)) * doubleIntegralOf F(x,y)DA
But its says above the parabola and below the x-axis, does that contradict each other?
There is no explanation in the answer but here it is :
The area of the region is 64/3 and the double integral of y over the region is 256/15. So
y_avg = 4/5.
Can you explain and show me how to do this ?
"bounded above" means that the parabola is the upper limit.
so is it just this :
1/2[tex]\int^{2}_{0} 4 - x^2[/tex]
And how about the double integral of it?
The parabola, y= 4- x2, intersects the x-axis at (-2, 0) and (2, 0). On the entire region, bounded by the parabola and the x-axis, x ranges from -2 to 2. For each x, y ranges between the x-axis and the parabola- from y= 0 to y= 4- x2. Those are the limits of integration:
[tex]\int_{x=-2}^2 \int_{y= 0}^{4- x^2} y dydx[/tex]
Of course, because of the symmetry, you can integrate from x=0 to x= 2 and double.
Notice that the double integral for the area is just
[tex]\int_{x=-2}^2 \int_{y= 0}^{4- x^2} dydx[/itex] and becomes
[tex]\int_{x=-2}^2 \left[y\right]_{y=0}^{4-x^2}= \int_{x=-2}^2 (4- x^2)dx[/tex]
[tex]= 2\int_0^2 4- x^2 dx[/tex]
What is the definition of average value?
The average value is a measure of central tendency that represents the typical or common value in a set of data. It is calculated by adding all the values in a dataset and dividing by the number of values.
How is average value different from median and mode?
While average value takes into account all values in a dataset, median only considers the middle value and mode represents the most frequently occurring value. Average value can be affected by extreme values, whereas median and mode are not.
What is the formula for finding average value?
The formula for average value is: sum of all values / number of values. It can also be represented as: Σx / n, where Σ represents the sum and n represents the number of values.
When should median be used instead of average value?
Median should be used instead of average value when the dataset has extreme values that could skew the average. In this case, median would better represent the typical value in the dataset.
How can average value be used in data analysis?
Average value can be used to summarize a dataset and provide a general understanding of the data. It can also be used to compare different datasets and track changes over time. In addition, average value can be used in statistical analysis to make predictions and draw conclusions.
