Homework Help: Finding confidence interval
  1. Apr 22, 2012 #1
    In a primary school, the mean height of the students of primary 1 students is 120cm. Given a sample size of 40, the confidence interval is 117 and 123. Find the confidence interval if the sample size is 30 instead.
    2. Relevant equations
    Standard deviation and confidence level is not given in this question
    3. The attempt at a solution
    It's a test, so I just gave it up due to not enough time to attempt to it. Test paper aren't given back, but I remember the question in details.
    However i ask my one of my classmate and his solution was 120 +- x/[sqrt(40)/sqrt(30)] though the reason he told was like rocket science to me
  3. Apr 22, 2012 #2
    I like Serena
    Welcome to PF, finalight! :smile:
    Do you have a formula for the calculation of a confidence interval?
    From it, you can deduce the effect on the confidence interval if the sample size changes.
    There is an assumption in your problem statement however.
    Apparently it is assumed that the standard deviation of the sample of 40 is the same as the standard deviation of the sample of 30.
  4. Apr 22, 2012 #3
    yes, i also assume that the standard deviation and the confidence level remain the same
    however, even with the given formula, i still do not know how to calculate the result, because there are two unknowns; the confidence level and the standard deviation itself
  5. Apr 22, 2012 #4
    I like Serena
    If you write down the formula for n=30 and also for n=40, you'll see that they have a part in common.
    You need to make use of that.
    Can you perhaps write down your formula?
  6. Apr 22, 2012 #5
    the general formula would be
    mean +- confidence level * standard deviation/sqrt(sample size)
    120 +- x * s/sqrt(40) = 117,123
    120 +- x * s/sqrt(30) = ?,?
    that's what i got, still can't see the similarity, except for the two unknowns there
    unless you want me to use simultaneous equation...
  7. Apr 22, 2012 #6
    I like Serena
    Let's give x * s another name.
    Let's call it A=x * s.
    So your first equation (only the lower bound) is:
    120 - A/sqrt(40) = 117
    Can you solve A from this equation?
    And then substitute the result in your second equation?
  8. Apr 22, 2012 #7
    so that means
    120 +- A/sqrt(30) = 117,123
    Equation 1: 120 - A/sqrt(30) = 117
    Equation 2: 120 + A/sqrt(30) = 123
    are you refering to something like that?
  9. Apr 22, 2012 #8
    I like Serena
    I meant you to substitute the solution for A into:
    120 +- A/sqrt(30) = ?,?
    Then you get the result you want (the question marks).
    Can you solve A from equation 1?
    Or from equation 2, which should give you the same result?
