Homework Help: Finding Cubic Functions
  1. Dec 12, 2012 #1
    I have a line of a cubic function that passes through (-10,4), (-2,3), (-1,2), (0,1), (7,0). I must find the function of this line.
    2. Relevant equations
    3. The attempt at a solution
    I know you cant see this but the line has a "S" curve to it. Making me assume that it is a cubic funtion.
  3. Dec 12, 2012 #2
    jedishrfu
    Staff: Mentor
    have you tried graphing it?
  4. Dec 12, 2012 #3
    I need to find the function, using those points, thats all that is given.
  5. Dec 13, 2012 #4
    jedishrfu
    Staff: Mentor
    I don't have an idea of how to solve it but if you look at just the y values what do you see?
    Are you sure you aren't simply to find the line that best fits the points?
  6. Dec 13, 2012 #5
    jedishrfu
    Staff: Mentor
    try starting with an equation of the form ax^4 + bx^3 + c^x2 + dx +e = y and generate a set of 5 equations in five unknowns using the the five points one by one.
    So start with (0,1) and you get simply e=1 now proceed to find the other constants.
  7. Dec 13, 2012 #6
    HallsofIvy
    Notice that jedishrfu has a fourth degree polynomial, not a cubic. That is because a cubic, [itex]y= ax^3+ bx^2+ cx+ d[/itex] has four coefficients which take four equations to determine. So there exist a unique cubic through any four given points. You give five points so there may not be such as cubic. Of course, if those points do lie on a cubic, you will find that the coefficient of [itex]x^4[/itex] is 0.
    Another way to find the polynomial (though I really prefer jedishrfu's method) is the "Lagrange polynomial":
    [tex]y(x)= 4\frac{(x+2)(x+1)(x)(x- 7)}{(-10+ 2)(-10+ 1)(-10)(-10- 7)}+ 3\frac{(x- 4)(x+ 1)(x)(x- 7)}{(-2+ 10)(-2+ 1)(-2)(-2- 7)}[/tex]
    [tex]+ 2\frac{(x+ 10)(x+ 2)(x)(x- 7)}{(-1+ 10)(-1+2)(-1)(-1-7)}+ 1\frac{(x+10)(x+2)(x+1)(x- 7)}{(0+10)(0+2)(0+1)(0-7)}+ 0\frac{(x+10)(x+2)(x+1)(x)}{(7+10)(7+2)(7+1)(7- 0)}[/tex]
    Do you see the idea? Each fraction has factors in the numerator of "x- " each x value except one. And the denominator has factors with that missing x value minus each of the other x values. If x is any one of the given x values, every fraction except one will be 0 and then the fraction will be 1 so that we just have y value that was in front. And, of course, because there were five points, each fraction has 4 factors involving x and so this will, in general, be a fourth degree polynomial.
  8. Dec 14, 2012 #7
    symbolipoint
    Education Advisor
    Ignoring the point, (0,1), the 4 x 5 matrix can be made:
    [-1000, 100, -10, 1, 4]
    [-8, 4, -2, 1, 3]
    [-1, 1, -1, 1, 2]
    [343, 49, 7, 1, 0]
    Using the online software www.math.purdue.edu/~dvb/matrix.html, the reduced row form is:
    1, 0, 0, 0, 0.0106
    0, 1, 0, 0, 0.0408
    0, 0, 1, 0, -.9518
    0, 0, 0, 1, 1.018
    The apparent coefficients give an equation that can be run through google and graphed. The result is interesting. Just type in, "graph 0.0106x^3+0.0408x^2-0.9518x+1.018" and see the resulting graph. As you inspect the points, you see a near, not perfect, fit to the five original given points and there are three roots. They are nearly x=-12, x=1, and x=7. My efforts this way may have a mistake somewhere since those roots as binomial factors do not give the same or similar coefficient for the cubic term. Maybe this is off only by a constant value factor?
