Calculating Eb/No for PSK and QPSK
  • Thread starter Tjvelcro
In summary: QPSK has two bits per symbol, so the signal power will be divided by 2.Plugging in our values, we get:SNR (dB) = 10log(1.25 x 10^-5 / 2.5 x 10^-8) - 10log(2) = 27 dB - 3 dB = 24 dBAnd the Eb/No (in dB) for QPSK is:Eb/No (dB) = 24 dB - 10log(10^-5) = 24 dB - 50 dB = -26 dBIn summary, for PSK, the Eb
Tjvelcro
A sine wave is to be used for two different signaling schemes: (a) PSK; (b) QPSK. The
duration of a signal element is 10^-5 s. If the received signal is of the following form
s(t) = 0.005 sin(2pi (10^6)t + theta) volts and if the measured noise power at the receiver is 2.5 X 10^-8 ,watts, determine the Eb/No(in dB) for each case.
Eb/No = ?
signal element = 10^-5s
I'm not sure where to start this problem, I assume the 10^-5s should be put into the main equation but I'm not sure what theta equals and what variable I will be solving for. Any help would be appeciated.
Tjvelcro
, thank you for your post. This is an interesting problem that involves understanding the relationship between signal power, noise power, and signal-to-noise ratio (SNR). Let's break down the problem and see if we can find a solution.
First, let's define some variables:
- s(t) = 0.005 sin(2pi (10^6)t + theta) volts is the received signal
- Pn = 2.5 X 10^-8 watts is the measured noise power at the receiver
- T = 10^-5 seconds is the duration of a signal element
- Eb/No = ? is the signal-to-noise ratio, which we will solve for
Now, let's look at the relationship between signal power, noise power, and SNR:
- Signal power (Ps) is the average power of the signal over a given time period. In this case, since the signal is a sine wave with an amplitude of 0.005, the signal power can be calculated as follows:
Ps = (0.005)^2/2 = 1.25 x 10^-5 watts
- Noise power (Pn) is the average power of the noise over a given time period. In this case, we already know that Pn = 2.5 x 10^-8 watts.
- Signal-to-noise ratio (SNR) is the ratio of signal power to noise power. It is typically expressed in decibels (dB) using the following formula:
SNR (dB) = 10log(Ps/Pn)
Now, let's plug in our values and solve for SNR:
SNR (dB) = 10log(1.25 x 10^-5 / 2.5 x 10^-8) = 10log(500) = 27 dB
This means that the SNR for the received signal is 27 dB.
Finally, to find the Eb/No (in dB), we can use the following formula:
Eb/No (dB) = SNR (dB) - 10log(T)
Eb/No (dB) = 27 dB - 10log(10^-5) = 27 dB - 50 dB = -23 dB
Therefore, the Eb/No (in dB) for this case is -23 dB.
For the second case, QPSK, we
1. What is Eb/No and why is it important in PSK and QPSK calculations?
Eb/No stands for "energy per bit to noise power spectral density ratio". It is a measure of signal quality and is used to determine the minimum amount of energy required to transmit a bit of information in the presence of noise. In PSK and QPSK calculations, Eb/No is important because it helps to evaluate the performance of the modulation scheme and determine the optimal parameters for transmission.
2. How is Eb/No calculated for PSK and QPSK?
Eb/No can be calculated by dividing the signal energy per bit (Eb) by the noise power spectral density (No). In PSK and QPSK, the signal energy per bit is proportional to the amplitude of the signal, while the noise power spectral density is related to the bandwidth of the signal. Therefore, to calculate Eb/No, one needs to know the signal amplitude and the bandwidth of the signal.
3. What is the relationship between Eb/No and bit error rate (BER) in PSK and QPSK?
Eb/No and bit error rate have an inverse relationship. As the value of Eb/No increases, the bit error rate decreases. This is because a higher Eb/No means a stronger signal, which is less susceptible to noise. In other words, a higher Eb/No indicates a better signal quality, resulting in a lower bit error rate.
4. How does the modulation index affect the Eb/No in PSK and QPSK?
The modulation index (m) is the ratio of the change in amplitude or phase to the carrier frequency. In PSK and QPSK, the modulation index affects the Eb/No by determining the amount of energy per bit that is transmitted. A higher modulation index means a higher signal energy, resulting in a higher Eb/No. However, too high of a modulation index can also introduce distortions and increase the bit error rate.
5. What are some common values for Eb/No in PSK and QPSK systems?
The required Eb/No value for a PSK or QPSK system depends on various factors such as the modulation scheme, channel conditions, and desired bit error rate. However, in general, a minimum Eb/No of 10 dB is considered acceptable for reliable communication in PSK and QPSK systems. Higher values, such as 20 dB or 30 dB, may be required for more challenging channel conditions.
  • Electrical Engineering
  • Nuclear Engineering
  • Math Proof Training and Practice
9K
