1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Finding eigenvalues of matrix
  1. Jul 20, 2009 #1
    Find the eigenvalues of the following matrix:
    [tex]
    \left(
    \begin{array}{ccc}
    1 & 0 & -3 \\
    1 & 2 & 1 \\
    -3 & 0 & 1
    \end{array}
    \right)
    [/tex]
    2. Relevant equations
    3. The attempt at a solution
    I think I'm forgetting a basic algebra rule or something. I know there are supposed to be 3 eigenvalues, but I am only getting 2.
    [tex]
    0=\det (\lambda I-A)=\left|
    \begin{array}{ccc}
    \lambda -1 & 0 & 3 \\
    -1 & \lambda -2 & -1 \\
    3 & 0 & \lambda -1
    \end{array}
    \right|
    [/tex]
    [tex]
    =\frac{(\lambda -1)(\lambda -2)(\lambda -1)-3(3)(\lambda -2)}{(\lambda -2)}
    [/tex]
    [tex]
    =(\lambda -1)(\lambda -1)-9
    [/tex]
    [tex]
    =(\lambda -1)^2-9
    [/tex]
    [tex]
    (\lambda -1)^2=9
    [/tex]
    [tex]
    \lambda =\pm 3+1
    [/tex]
  3. Jul 20, 2009 #2
    Re: Eigenvalues
    Where you cancel the (lambda - 2) term, you lose one solution: lambda = 2.
    Remember, you have to factor. By canceling the term (lambda - 2), you're basically saying "lambda cannot under any circumstances equal 2". If you want to do that, you have to consider two separate cases: lambda=2 and lambda!=2.
    So the three eigenvalues are 3+1=4, -3+1=-2, and 2.
  4. Jul 20, 2009 #3
    Pengwuino
    Re: Eigenvalues
    Why did you divide by (lambda - 2) in the first place?
  5. Jul 20, 2009 #4
    Re: Eigenvalues
    Thanks for your help.
    So let me get this straight. Whenever I divide by a term to cancel it, I count that term as one of my solutions, right? Does this always work? I didn't quite understand what you meant by testing two separate cases.
  6. Jul 20, 2009 #5
    Re: Eigenvalues
    Because it was much easier to do that than it was to multiply everything out and try to factor a third-degree polynomial.
  7. Jul 20, 2009 #6
    Re: Eigenvalues
    Why did you divide by lambda-2 in the second line of your equations? Do you remember the formulas for a determinant of a 3x3 matrix?
  8. Jul 20, 2009 #7
    Re: Eigenvalues
    Oh, duh. Since there are two terms on the RHS and they are constants then the must both be equal to zero separately. Haha.
  9. Jul 20, 2009 #8
    Re: Eigenvalues
    You can just factor (x-2) to get an easily solvable equation
  10. Jul 20, 2009 #9
    Re: Eigenvalues
    I was just doing two steps at once. Bad form on my part.
  11. Jul 20, 2009 #10
    Pengwuino
    Re: Eigenvalues
    Yes. Think of it this way, let's say you're trying to find the solutions of x for (x-1)(x-2)(x-3)=0. Obviously your solutions are x=1,2, and 3. If you divide out (x-1), you lose a solution and are left with (x-2)(x-3)=0.
  12. Jul 20, 2009 #11
    Re: Eigenvalues
    Very good point. Thanks!
  13. Jul 20, 2009 #12
    Pengwuino
    Re: Eigenvalues
    Your welcome. Also, to clarify AU's point, when you divide by (lambda-2), your left with that (lambda-2) in the denominator of the left hand side (the 0). Now for any number other then 2, it's going to be 0 divided by some finite number which is 0. However, with lambda = 2, you get 0/0 which is undefined, not 0.
  14. Jul 20, 2009 #13
    Re: Eigenvalues
    Aha. That makes sense now.
