Finding F
  • Thread starter -EquinoX-
http://img245.imageshack.us/img245/7535/38187200.th.jpg [Broken]
I need to find F from the picture above
My answer so far is:
[tex] \frac{-y}{(x^2+y^2)} \vec{i} + \frac{x}{(x^2+y^2)} \vec{j} [/tex]
is this correct?
Answers and Replies
benorin
Insights Author
1,395
150
No. The magnitude is at a distance r from the z-axis should be 4r. recall that [tex]r=\sqrt{x^2+y^2}[/tex]. Note that your "answer so far" has the properties depicted except that it has magnitude 1/r at a distance r from the z-axis.
so it should then be:
[tex] \frac{-y}{4(x^2+y^2)} \vec{i} + \frac{x}{4(x^2+y^2)} \vec{j} [/tex]
benorin
Insights Author
1,395
150
Does [tex]\sqrt{\left(\frac{-y}{4(x^2+y^2)}\right)^2 + \left(\frac{x}{4(x^2+y^2)}\right)^2}=4\sqrt{x^2+y^2}[/tex]?
No. Look, [tex]-y\vec{i}+x\vec{j}[/tex] is a vector field whose vectors point in all the right directions, make them the proper length.
I have no clue.... I've tried [tex] -4y\vec{i} + 4x\vec{j} [/tex] and it seems to be wrong as well
HallsofIvy
41,847
969
is this correct?
As benorin said, your first attempt had magnitude 1/r and it should be 4r. For your second attempt you just divided by 4. That makes the magnitude 1/4r, not 4r. You need to multiply your first answer by 4r2= 4(x2+ y2).
so it's just simply:
[tex]-4y\vec{i} + 4x\vec{j}[/tex]
Related Threads on Finding F
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
