Homework Help: Finding force parallel, HELP
  1. Dec 1, 2008 #1
    A 50kg crate rests on the floor. The coefficient of static friction is .5. The force parallel to the floor needed to move the crates is most nearly:
    Choices:
    50N
    125N
    250N
    500N
    2. Relevant equations
    I have no idea what equation to use for this equation.
    3. The attempt at a solution
    No attempts yet since I don't know which equation to use.
  3. Dec 1, 2008 #2
    rock.freak667
    Do you know the equation that F=uR, where F is the frictional force and R is the normal reaction?
  4. Dec 1, 2008 #3
    I have seen it before but my teacher never really used it. But I would like to learn how to use it. Can you show me?
  5. Dec 1, 2008 #4
    rock.freak667
    Firstly, you'll need to find the normal reaction,R. In this case it is simply the crate's weight. When you have that, put that into F=uR where u is the coefficient of friction. Then compare the value of friction that you get to the answers given.
  6. Dec 1, 2008 #5
    Ok. That sounds pretty easy. So for that it would look like this..
    F= uR
    F= (.5)(50)
    I guess I multiply right? And that gives me 25N but that isn't an answer.
    Did I do something wrong?
  7. Dec 1, 2008 #6
    rock.freak667
    50kg is the crate's mass. To find its weight you need to multiply the mass and the acceleration due to gravity
  8. Dec 1, 2008 #7
    Ok. So to find the weight I take 50kg and times that by acceleration which is 9.8 (gravity)
    To get 490.
    Correct?
  9. Dec 1, 2008 #8
    rock.freak667
    yes that is the weight of the crate and hence its normal reaction. Now what is the frictional force (this also is the frictional force which causes the crate to be in limiting equilibrium)
  10. Dec 1, 2008 #9
    Would it be .5? I don't really know.
  11. Dec 1, 2008 #10
    rock.freak667
    Try F=uR => F=(0.5)(490)
  12. Dec 1, 2008 #11
    Ok.. so the answer would be 245N but the closest one I have is 250N.
    Thanks!!
