Maximizing Gain in Op-Amps: Exploring the Ideal Op-Amp Property
  • Thread starter Cocoleia
  • Tags
    Gain
In summary: You should be able to spot the problem with this circuit without writing any equations, and in fact you were on the right track in your early posts where you recognized that the magnitude of the gain would be the full gain of the ideal op-amp (infinite).It was a bit off track since you were solving for Vs, which should be an independent variable and not dependent...No, you've lost the path from the output to the "-" input. When you combined the 60 kΩ and 30 kΩ, the resulting 20 kΩ should still be connected to the 80 kΩ resistor.Ask yourself if there is any effective feedback that will limit the gain of the circuit. Can any amount
Cocoleia
295
I need to find the gain in this question.
I know gain will be Vo/Vs. I did many calculations to end up with Vs being 0. Would this be logical? I know ideal op amps will have infinite voltage gain, so if you divide by 0 then it will go towards infinity? So I'm not sure if that would be correct for this question.
You should find Vo/Vs as you say, you don't "find" Vs.
Write the KCL equations for the nodes, and use the properties of an ideal opamp to help simplify the problem. Please show us the KCL equations, and your work toward solving them. :smile:
I'm not really sure what to do in these problems but that was what I tried
Sorry, I'm not able to read that. Can you try scanning the pages to see if they are more readable that way?
You might want to simplify the resistor network first, since it looks like there are parallel and series opportunities to exploit. You'll have fewer nodes and equations that way!
Can I suggest you take a good look at the circuit and see it you can simplify it before starting with equations.
Oh bother gneil beat me too it.
Ok, I will try to simplify that first. But do I have the right idea, would I use the same methods once I simplify?
Let's see your reduced circuit first. It may not be worth writing equations for it :wink:
Looks like you can still simplify it a bit more.
like this? I don't know how to connect the op amp. After do I write equations?
The 80 kΩ and 20 kΩ resistors are in series and can be reduced to a single 100 kΩ resistor. But the circuit layout is fine. The op-amp is connected as it was in the original circuit and will behave the same.
I'm not sure what the problem is.
Is what I did in my first posts correct or completely wrong?
Ask yourself if there is any effective feedback that will limit the gain of the circuit. Can any amount of current fed back from the output through the 100 kΩ change the voltages that the op-amp sees at its inputs?
It was a bit off track since you were solving for Vs, which should be an independent variable and not dependent on the circuit operation. It's an input. However, you did recognize that there was some kind of problem since it appeared that infinities were springing up.
Isn't the current entering the op amp supposed to be 0A? for both inputs
Yes, but feedback is supposed to cause changes in potential differences on components leading to those inputs. Can any amount of current through the "feedback" path make any difference in the potentials at the op-amp inputs in this circuit?
If it is too big? I'm not sure I understand, my professor never mentioned feedback in his notes.
Feedback is what sets the gain of an op-amp circuit. The so-called open-loop gain of an (ideal) op-amp is infinite. Feedback "closes the loop" and controls the overall gain of the circuit, limiting it to some finite value.
Effectively in this circuit the 100 kΩ resistor does nothing to control the op-amp's gain.
How can I explain that is going to be infinity in my answer ? How do I prove this, are there calculations etc ?
It's a property of the ideal op-amp. All you have to say is that the potential difference between the inputs is driven directly by Vs. Then refer to the relevant property of the ideal op-amp.
Ok, thank you very much !
1. What is gain and how does it relate to opamps?
Gain is a measure of how much an opamp amplifies a signal. It is typically expressed in decibels (dB) and is calculated by dividing the output voltage by the input voltage. Opamps are electronic devices that can amplify a signal by a certain amount, known as the gain.
2. How do I calculate the gain of an opamp circuit?
The gain of an opamp circuit can be calculated using the formula: G = -(Rf/Rin), where Rf is the feedback resistor and Rin is the input resistor. This formula assumes an inverting opamp configuration. For non-inverting configurations, the formula is G = 1 + (Rf/Rin).
3. What is the difference between inverting and non-inverting opamp configurations?
In an inverting opamp configuration, the input signal is connected to the inverting input terminal, while the non-inverting input terminal is grounded. This results in a negative output voltage. In a non-inverting configuration, the input signal is connected to the non-inverting input terminal, and the output voltage is the same polarity as the input signal.
4. How do I choose the appropriate opamp for my circuit?
When selecting an opamp for a specific circuit, factors such as input and output voltage range, gain, bandwidth, and slew rate should be considered. It is also important to ensure that the opamp can handle the desired frequency and power requirements.
5. Are there any limitations to the gain that can be achieved with opamps?
Yes, there are limitations to the gain that can be achieved with opamps. These limitations include the power supply voltage, input and output voltage range, and the opamp's internal circuitry. Additionally, high gain can lead to stability issues and increase the chances of noise and distortion in the output signal.
  • Electrical Engineering
  • Science and Math Textbooks
